1 - 20 of 41 Posts
What would you say is the best way to repair a leak in a 3" pvc stack in a wall that is leaking from 2 screw holes about 1" apart caused by the closet hanger system?
Cut the pipe and install a no hub?
Clean the holes and roll glue into them?
Silicone?
Something else?
Cut the pipe And install 1 pvc slip coupling, & 1 reg coupling. Or if the pipe has no play side to side, use 2 slip couplings.
I've done this many times. Got big channel locks, that are actually for sink strainers, that I use to grip the couplings, & slide them into place, after glue is applied.
Make sure pipe is not split at screw hole. I'd replace atleast a foot or so of it, just to be safe.
OldSchool said:
I wonder if you could fix that with a soldering iron
I've had to use a plastic fusion welding rig for pvc repairs dozens of times.
I have a "friend" who glued 3/4's of a coupling on a sch 40 storm sewer he accidentally sawcut the top couple inches of.
"He" applied primer and glue to both pieces and snapped the split coupling onto the pipe.....
I would never do that personally:whistling2:
I would think you should be able to melt the pipe... even if you use a piece of pipe to use as a stick and melt it...
Heat gun might work also
I have a cousin who has a plastic welding shop here in town... he can weld just about any type of plastic
I have a coupling patch in my house...It's on the top, but it's there....
I would think a soldering iron would work also, but I'd be concerned about hair line cracks that could possibly leak.
sent from the jobsite porta-potty
Reactions: Epox
A typical hot air plastic welding rig. I've used both this style (with fan) and the compresssor/regulator style.
Work wonders
Plumbing Troubleshooter
If it's for a customer, cut it out and repair.
For yourself, any one of the many rumored quick fixes listed here may work out just fine.
gladerunner said:
Teflon tape the screws and put the back
It's that a joke or r u being serious?
Hot aie plastic welding is not a "rumoured quick fix". I had to employ it under supervision of the local inspector numerous times.
For the right application, it's worth its weight in Canadian Loonies!
:laughing:
Reactions: OldSchool
1 - 20 of 41 Posts
