1 - 11 of 11 Posts
Anyone ever install any?
1000 pound rating. I think we will be doing alot of these in the future.
What say you oh mighty PZ?
No, but funny you should bring it up. Everytime I see a woman that's larger than the average redwood tree, I feel sorry for her toilet.
Ack, bad visual!
Discussion Starter #3
Unfortunately, folks keep getting fatter. Maybe they will thin down as we enter The Great Depression Version 2.0
I just learned something new. And I just got a request from a large chain store to bid on fixing all their wall hungs that have pulled off. Thanks Il Plumber
Oh, is that why those wall hung closets are pulling away from the walls at those diet clenics, dosen't answer why the urinals are doing it too, I guess we will need to run 6" drains to them also.
Discussion Starter #8
I don't guess I understand how a wall hung WCL can pull away from the wall?
Sloppy install?
Do some folks not use carriers?
Around here the wall holds no part of the china. We leave about an 1/8" gap to be caulked. The carrier carries ALL the load.
every tool is a hammer
Super,
how much do these cost? I am at various Red Lobster restaurants working on toilets constantly. They spec floor mount flushometer types. A lot of their customers are bigger than necessary and they shake 'em up. I think it would help if the toilets ADA height. Those last 3 inches till their ass hits the seat really makes a difference. A lot of times, the only thing holding the toilet to the floor is the flushometer.
Sloppy install?
Yes, sloppy installs, I've seen many 2x4's wedged between the walls for added support, but it's usually the single carriers where the rear anchor pop's or becomes loose on those I like to through bolt them to the deck below if possible.
Master Plumber/Mechanical
Does that require a 5" drain
For every 300lbs increase by one pipe size?
Sorry if I offend anyone Butt really?
1 - 11 of 11 Posts
