Was the valves like the one's I was talking about; the no namers? or was it a watts, legend, sioux chief...etc?I just had that happen a couple weeks ago. Get it all soldered up and water back on and then there it is a brand new ball valve leaking at the seem.
I hate tearing things out that I just did.
Legend makes a decent product, too, in my opinion. I agree, it blows to cut your work out soon as your done!Sorry it was a legend..
Legend ball valves are junk...Legend makes a decent product, too, in my opinion. I agree, it blows to cut your work out soon as your done!
Interesting. Yeah, never had a problem with Legend here.Legend ball valves are junk...
they cant handle the heat when you solder them with an acetylene torch
and leak at the threaded joint right from the get go
Nibco seems to be the best quality around here
Sounds like you need to be more careful or use a smaller tip. Regardless of your torch, you shouldn't be overheating anything.Legend ball valves are junk...
With the legend ball valves it always seemed to leak at the threaded joint that bonded both ends together..Sounds like you need to be more careful or use a smaller tip. Regardless of your torch, you shouldn't be overheating anything.
They probably use cheaper lead free brass. Good lead free brass that is easy to machine, dezincification and corrosion resistant, and easy to solder is expensive. We use mostly Red White valves, I don't usually have issues soldering them and all the seals are Teflon.
Thanks for leaving the good deals for me 😘Buying stuff like this on Amazon or eBay is not a great choice. I buy it in a store near my house. It's the only way to know if the valves are any good.
We get RWV valves with packing nuts. But you don't know if the ball seals are good until you turn the water back on.I bought a legend ball valve at the supply house, soldered it up and had water coming out of the seem. I can't tell a good one from a bad one.
More than half the stuff you see on E-bay has probably been stolen by employees off their service
trucks and then re-sold in bulk ..... that has been going on for years....
One good example --- 10 rolls of sterling silver solder for 10 bucks each....
