Sorry for the mis leading title, tried to change it but could not
I was reminded of a job I had done with CPVC. After we got done we applied 110 psi to the lines. They held up good. We started the DWV and about 4 hours later we heard this sound that sounded like a gun shot going off upstairs. We ran up to see and we could hear a hiss. Come to find out the someone forgot to glue the stub out for the toilet:whistling2:
It held 110 psi for about 4 hours before it finally turned loose!
Oh yeh, we spent the rest of the day checking all the joints!
After the inspection we connected the water main, turned it on and had no water hot or cold to the bathroom! I figured that we forgot to glue another joint, so we searched and found both pipes had been cut off by the HVAC man who said nothing at all to us. After we fixed that one we had tested the water, everything was fine. We shut the water down. After the addition was done we were asked to turn the water back on. I had a bad feeling so I connected the air tester again just to be safe, and lo and behold, there was a leak. We found that the cabinet man had used 3" screws and missed the stud, but not mu pipe. We fix that, re test with air and another leak! Found 2 places in the back bathroom where the GC had used 2-1/2" finish nails to install wainscotting and missed the studs! I tell you we had one hell of a time with this place. I made more money repairing leaks from the other screw ups than the job paid in the first place!
One of those "I wish I had not done this" job!
