and the pvc pipe is missing...Maybe this'll help sort it out.
I dont use condensate pumps, I usually gravity drain after neutralizing the condensate...most of the wall hungs are non condensating units, the last one in went on a 2nd floor boiler room and condensate line went down and out the foundation..That's because the coupling will be attached to more pvc pipe which will run into a condensate pump which will be plugged into that outlet.
But you already knew that.
ill fix it for you..most of the wall hungs I install are not condensing..look up takagi smarta$$...I'm just gonna let that one speak for itself.
geez bro just having some fun..didnt mean to scare you...:vs_laugh::vs_laugh:I think we've had enough for the night.
I dont like those wall hung combos...ill only put in the takagis and they come both condensate and non condensing...look it up and see...
absolutely bro, ALL IN FUN ALWAYS...no harm no foul....passing along real info but having fun at the same time..otherwise it would be boring as hell ...Look bob, all machismo aside, I just want to make it clear that I too do this all in fun and I like that we can have regular discussions about things like how I have electrocuted myself while we are also calling eachother children and knit picking eachother's arguments.
I don't like everything about you, but I like more about you than most.
did this a week or so ago, i still have some old rigid brand 1/2" OD benders that i have used about 5 times in the last 25 years or so......
https://www.plumbingzone.com/picture.php?albumid=70&pictureid=7774
my sister bought one of those toilets and I got stuck installing it..PITA..but it came with polished brass cover plates to go over the bottom pipe hookups so you dont see anything but brass,,and the tank was clad in wood..i agree those white plastic parts look totally out of place, but came that way from factory, so no changing them for now, seat is white as well.
I know what you're getting at. My theory is that PVC and ABS are rated for it.and the pvc pipe is missing...
nope, that wasnt my point..I was just busting skosos balls...abs is not legal in my area, so all lines like that are pvc....im a big believer in keeping things simple..the more components you put in a system is just 1 more thing to fail..the few times I used a condensing unit I gravity drained it to a drain or outside...I know what you're getting at. My theory is that PVC and ABS are rated for it.
....that is a closet riser.did this a week or so ago, i still have some old rigid brand 1/2" OD benders that i have used about 5 times in the last 25 years or so......
