1 - 4 of 4 Posts
· Registered
It has an integrated porcelain spout. The customer has two of these. The valves are getting a little worn out after 100 years of use. Any ideas for replacement?
The only thing I can think of involves machining a custom brass ring and using a modern widespread valve body. The ring would go between the bottom nut and the bottom of the sink. It would have a hole drilled from the outside which would accept 3/8" OD copper to solder in. There would be another hole drilled in the face near the center bore where the ring would contact the porcelain. It would work like a brake line fitting where it attaches to the caliper.
It also occurs to me that I could drill a hole through the side of a widespread valve body at the correct point and then just cap the 1/2" leg out.
· Registered
I hear a 75K lawsuit which you'll have to pay all by yourself when it ruins half their house because you decided to play the engineer.
CAD or USD?
Reactions: dhal22
· Registered
Discussion Starter · #4 ·
Whether this goes into the customers house or not I would like ideas on a solution. If this doesn't go into their house it's going into mine because they'll have to get rid of these sinks altogether and they are in extremely good shape.
1 - 4 of 4 Posts
