Let this be the catch all for one of the most incorrectly made water heaters I've seen in my plumbing career. For those of you who come to this site seeking information about these water heaters, I'll do my best to provide pictures that don't require you to log on/register to see, so I'll link off of photobucket to do so.
In my area of Kentucky, The Lowes Store that sells Whirlpool Water Heaters:
They are sending out on average, 30 burner assemblies, along with a number of gas valves per week, nearing 150 units a month with customers that have malfunctioning water heaters.
A Lowe's Whirlpool Water Heater is made by the American Water Heater Company. It is also named as the CRAFTMASTER. There are also other brand names that have been using this unit which will be named in this thread once I get clarification from the right resources.
If you want to describe your situation, file a complaint then you need to go here to get your voices heard and find out what others are dealing with in their purchase.
The issues of this water heater involve premature thermocouple failure, burner assembly malfunction, gas thermostat malfunction. Another problem is the spark arrestor for intake air found directly underneath these water heaters that clog easily due to simple dust buildup and the most likely known problems with these units starving for oxygen have been directly related to cat hair. Cat hair is extremely fine and if you have a cat, this water heater can fail prematurely due to buildup under the unit.
These water heaters have a FEDERAL LAWSUIT following the failures of these gas fired water heaters. In order to retain your replacement retrofit parts at any LOWES Home Improvement Store you will need a SERIAL NUMBER along with MODEL NUMBER off your gas water heater so they can track the units in use that register back to the federal lawsuit.
To contact American Water Heater Company
1-800-999-9515
or visit them online at http://www.americanwaterheater.com and click on the Contact us online link.
What to Expect
When you first contact the mfg. of your water heater regarding problems, you'll be asked the following:
Model Number
Serial Number
These two series of numbers dictate the age/lot run/# of gallons/ the water heater is.
Then the technician will ask numerous questions of what you are experiencing. Troubleshooting questions with your answers will dictate the problem solving solution.
WARNING: Left handed threads are used on these units. Incorrect installation will cause cast aluminum threads to damage, resulting in gas thermostat becoming non-functional.
WARNING: You must remove burner orifice and install on new burner assembly when switching out defective parts. Non-installation of this will result in excessive gas consumption and overheating of unit, causing damage to wiring harness and destroying temperature sensor.
WARNING: You must carefully reinsert the panel screws that hold the panel to the burner assembly onto the formed opening of the water heater without damaging the nutserts. Incorrect installation will result in stripping of these screws which will not seal the combustion chamber. This will lose the protection of FVIR (Flammable Ignition Vapor Resistant) design found on your water heater.
Do NOT attempt to work on this unit if you are not aware of the inner workings of how this unit operates. Contact a licensed professional plumber to perform these duties as someone not aware of the numerous considerations to retrofit your existing water heater could spell financial loss.
I'm going to post a terrible situation that unfolded for one customer of mine, and how much money it is costing just to have hot water back.
1-800-999-9515
What to Expect
Model Number
Serial Number
