Hi,
Sorry if I posted in the wrong section I'm new, and a bit desperate.
I just had a new hot water system (gas) 135L installed, brand is Vulcan. 4 hrs have passed since it was installed and the water is dead cold (the hot tap). When I first tried it, the water was hot so I thought it was fine but then suddenly it started spitting crazily at me (air), for a while, then it stopped, but the water was cold from there on.
I went out side and the heater furnace fire was off, currently set to temperature setting 5 of 7, I turned it to 6 and then the furnace lit up, couple hours later, the water is warm for 10 seconds if lucky, then dead cold. Is this normal because according to google, it takes 40-1.5hrs max to full heat up.
I called the owner of the company and he says I need wait more hours. This cost me 1.5k!
