21 - 28 of 28 Posts
Discussion Starter · #21 ·
The public is ALWAYS correct,haven't you figured that out yet???lolololololololo,I would not work for her unless she pays up front,she will blame you for something else,it's coming
Case is now closed. She sent a video, Cast iron coming out of the concrete then rotted copper stack with a big patch of tape under the clean out. I told her somebody already hid the fact it was rotted with tape and I didn't do this type of job if I had to restart from under the slab. (floor would need to go) I wasn't going to try PC4 for a new joint at the cast to find out later it starts to leak.
Soooo did she apologize to you or did she just go away in a big huff???
Discussion Starter · #23 ·
No apologies, I felt she was on the fence of believing me the pipe was rotted. No huff either. Good news is I have video proof if she tries anything plus the signed contract she acknowledges she put acid in the drain.
you ought to ask her for a good review just to chapp her ass
and if she gives you a bad review, turn the tables on her and sue her like
she wanted to do to you...
turn-about is fair play
Pornstar, Service Plumber
......I wasn't going to try PC4 for a new joint at the cast to find out later it starts to leak.
Oakum and Lead Wool.
Plumbing
I hate that Kindah sh!t. “My water heater worked fine untill you snaked my sewer line the other day”.
Listen to this sheet
I pull up on a servi call and the neighbor runs out the front door “ when the power turning back on ? “ I say, Ma’am I have no idea I’m a plumber and I’m here working for your neighbor. She Says “ The power turned off when you pulled up so I want to know when you’re leaving because I need the power back on “. WTF bish ! You on drugs ? I’m the plumber !!! She ran inside.
21 - 28 of 28 Posts
