1 - 2 of 2 Posts
Exact model change out. Easy as pie cuz it bolts right into the old one’s brackets and everything lines up perfect with no offsets:clover:.
Why did the old one fail? The installer used lots of oil based flux and it all ran down outlet header and pooled in the bottom cap and corroded right thru after 10 years. Even so, the system had already paid for itself and then some. Other than the crusty panel (which was left to leak for months before they finally had it fixed) every thing is original. Pump, differential controller, tank, valves and sensors all still work perfectly.
1 - 2 of 2 Posts
