21 - 40 of 53 Posts
· I aint CPV see in it?
A real plumber who does real kitchen commercial will throw those included POS basket strainers in the garbage where they belong and provide and install a T&S or B&K trip lever waste drain that will accept a 2” female or 1-1/2” male with no problems at all. You guys are trying to make chicken soup with chicken sh!t.
· Super Moderator
I just install a 3 compartment sink and heat up the fitting
get my torch and heat up ABS FEMALE ADAPTER enough to soften the fitting.
it helps and you can continue with ABS SCH 40
hope it helps
and continue with ABS SCH 40
Read the forum rules and post a proper into.
· Registered
I have ran into a 3-compartment sink at a DairyQueen that the pvc glue joints kept melting because they were using scalding hot water at that sink,I had to repipe it using multi purpose glue to keep glue from melting over time
· Registered
Why not repipe it with copper or no hub?
They didn't want to pay for it,cheap as possible get it done
Close the sale dude. you dont take no for an answer. Assert your dominance and knowledge and you tell THEM what you are going to do. And to hand you that complimentary blizzard on your way out the door as the sun beams down upon you while you soak in all the glory of being the baddest MF in your tri-state area, then wipe your mouth with the american flag climb into your truck with the baby seal skin seats and roll out.
· Registered
Is that what you do when you use cpvc mains on commercial jobs ? 🤣
21 - 40 of 53 Posts
