1 - 16 of 16 Posts
To replace this 7 year old Gerber POWER FLUSH that just started leaking... :laughing:
All I've found so far are 12" rough, trying to avoid major surgery. Any help is greatly appreciated.
I have installed a few 10" rough standard tank toilets back years ago. i cant remember who makes them, but they worked on 10" opening.
Why was the bowl turned? Its hard to tell if it was due to the flange being too close to the main wall. What is the distance from wall to center of flange? Is the white thing under the lav in the way for the bowl to turn? I think major surgery is going to be your only option unless you do the same thing that is already there but less hackish.
Discussion Starter · #10 ·
They drilled holes through the back of the tank to secure it to the wall. The toilet was originally straight but they wanted more room because the tub was right in front of the bowl, hard to tell from picture. That was the other plumber's solution to their request.
The customer's son has some kind of disability.
I might get lucky with this toilet: www.vintagetub.com/p/RM5050/Randolph-Morris-Two-Piece-Elongated-Front-Corner-Toilet
It's a major surgery job, but would a wall-hung geberit or toto with a tank in the wall work? I had a similar job where accessibility was an issue and the clearance in front of the toilet was minimal, so we put a wall hung in and saved about 8"
Discussion Starter · #12 ·
Possibly, but a 10'' corner toilet would be the least expensive & least complicated option. If it exists...
If the flange is at 12" off both walls you will be fine with that toilet. 16" diagonal from the wall corner like they state would be in the (off the top of my head) 11" to 11.5" range from each wall. If it is 12" diagonal like the diy reviewer said, which i doubt they measured properly, then no.
Put in a round front bowl instead of that elongated, that gets a little more room. Not enough extra room with that option?
Although it looks like complete crap, I'm pretty impressed with the creativeness and that it doesn't leak (assuming it doesn't leak).
Sent from my iPhone using PlumbingZone
1 - 16 of 16 Posts
