1 - 20 of 20 Posts
LeMarr Plumbing, Inc.
Where or is there a place that makes these?
I need to get on to 1/2 galv (compression) and then transition to 1/2 cts (fip or mip).
The galv has been cut and already has a dresser coupling (repair pvc). But when I do what I need to do, I will have to take it apart and put back (new one) and I don't want to use that style.
In Christ,
Song Dog
You could use a 1/2" galvy dresser coup. with a 1/2 brass nipple.
Cant thread old galvy so if your going to repair it the dresser coupling if properly installed will outlast the pipe or whats left of it.
Illinois Licensed Plumber
I never had trouble cutting old galvanized and threading it. I have had people call me all the time to install a ice maker line for them, and since saddle fittings are illegal here in Illinois, I just cut the old galvanized line thread it and put in a tee with a threaded union. No issues ever.
Yeah I guess galvy doesn't rust in IL. I heard only the best galvy pipe went to IL. iIguess that proves it.
Sarcasm noted.
I have came across some galvanized pipe that had a leak in it, I just unthreaded it out from the fittings and replaced it with a new piece and a union. I never liked the dressler couplings, I will do anything I can do to avoid using them.
Must be, I have worked in high rises that have had the same galvanized risers in them for over a hundred years. Maybe it only goes bad when you exceed fifty floors.
dressers ok if you restrain the pipe but yeah i would rather just replace it. Somtimes its so far gone tho. I'll use a dresser for a temp fix and with galy water pipe around here the glavy is so bad anyway that its for sure temporary
Discussion Starter #10
My deal is:
It has already been cut. There are the H&C lines feeding upstairs and are between floor joist and right above a beam. I am repiping her basement only. There are dressers already there but I don't like them. As mentioned, I am afraid they will blow apart. Where they are located I can't get a threader in there. I have one and it won't work. I want to get the fittings before I start.
In Christ,
Song Dog
Other than myself and my family, I have never heard anyone one else call them by there proper name until now.
Heh.. I never use dressler couplings, I fire up the pipe threader and put some threads on that there pipe.
every tool is a hammer
It's the Lake Michigan water. Ron and KTS both work primarily in Chicago and the surrounding suburbs. Galvanised lasts a long time there. When you get out a little south, most of the municipal wells are in limestone formations. Joliet is full of old limestone quarries. I have run into 50 year old galvanised water lines that are still good, but the drains don't last as long.
if you have to use a compression fitting on galv. try a "ford" or "muller" coupling had them to 210# in a 2"pvc 90 left it over night to prove a point and I was right they held. I gave up on dresslers long ago. But first i'd try threading the pipe.
Discussion Starter #16
I asked a salesman of mine about the Fords. Smallest they come in is 3/4. Thats is what I was wanting.
In Christ,
Song Dog
It cant blow apart if you restrain the pipe. The couplings job is to seal the pipe,not hold it together.
Discussion Starter #19
WOOOOHOOOO! I think I found them. I ordered 6 to have some on hand.
In Christ,
Song Dog
1 - 20 of 20 Posts
