Advantages of the Most Common Plumbing Vents - Plumbing Zone - Professional Plumbers Forum
Like Tree30Likes
Old 02-04-2020, 12:52 PM   #1
Default Advantages of the Most Common Plumbing Vents
There are several ways to install plumbing vents in a home. When considering which one to use for a specific project, the best way to make a choice is to start from what you can see in front of you. Then you’ll be able to visualize the pipes inside the wall.
As a first step, you may want to open up the cabinet under the sink and locate the P-trap. This is the starting point for the sewage/ventilation process in the home. The drainpipes connect the sinks, showers, bathtubs, the dishwasher and the washing machine to carry wastewater out of the system. This water then moves into larger drainpipes as it continues to collect through the house and moves toward the stack. The soil pipes do the same thing for the home’s toilets.
Types of Ventilation Used in Plumbing
There is more than one type of ventilation typically used in plumbing. Each one is used in different circumstances and it’s important to choose the right one each time.
True Vent
The true vent runs vertically. It is attached to the drain line through the roof. It is the best option if the fixture you are installing is positioned close to the stack and is on the top floor of the home. This strategy will allow the stack to serve as a vent.
True vents don’t have any water running through them. They must stay dry while the water runs down the drain. A wet vent will serve as a drain line; it will be large enough that it never actually fills with water, thus allowing air to flow simultaneously.
Auxiliary Vent
Also known as re-vent pipes, auxiliary vents are attached to the drain line close to the fixture as they run up and over the main vent. This option gives you some flexibility, as auxiliary vents can be attached right behind the fixture or horizontally to the drain line. Consider using auxiliary vents when the sink is situated too far from the main stack.
Common Vent
In a situation where you have two fixtures that are going to be installed on the opposite sides of a wall, they can tie into the stack with a sanitary cross. This technique is called a common vent. You would use it when installing back-to-back sinks.
Loop Vent
For a small bathroom, many homeowners may consider a freestanding sink. This is an especially popular choice in a powder room, where space is often at a premium. In this instance, a loop vent will work quite well. It circles up before connecting to the drainpipe, which allows for sufficient ventilation to occur behind the fixture. There is a wet vent close by, but these are generally reserved for bathtubs that are situated close to a stack. If wet venting is not allowed by your municipality, you may need to install a separate vent pipe through the roof.
Air Admittance Valves
This is an alternative to venting that is permitted in some jurisdictions. Air admittance valves are a new option, and they allow air to enter them as waste drains, then they rely on gravity to seal up before any gases can escape into the room. Depending on the size of the building and any code restrictions indicated for your area, air admittance valves can be used to vent several fixtures. It’s worthwhile to check the local codes to find out whether this type of plumbing vent is permitted in your area.
Which types of plumbing vents do you use most often? Do you have a preference? Have you ever used the new air admittance vents?
Old 02-04-2020, 04:25 PM   #2
vents..who needs stinking vents???.they just waste all that extra pipe...
Venomthirst (02-04-2020)
Old 02-04-2020, 05:48 PM   #3
Yep the diy don't need them and when they decide to play plumber they leave the pipe to open air inside a wall.
chonkie and Venomthirst like this.
Old 02-04-2020, 07:31 PM   #4
Venomthirst's Avatar
whats even better is how my house is plumbed in... No vents for anything.. bathtub doesnt have trap.. thats the vent lmao.. Good thing i have a building trap..
No i dont own it
Old 02-04-2020, 08:09 PM   #5
No i dont own it
I don't have a vent for my kitchen sink or the lavatory. That's how it was done in 1952. The only vent is 1 1/2" from the stack to the attic and 3" through the roof.
Old 02-04-2020, 08:16 PM   #6
there are plumbing systems over 100 years old and not much is vented and it worked fine and some still working today....but the more complicated they can make the systems the more $$$$$ some manufacture is making for supplying all the pipe and fittings...
Old 02-04-2020, 09:06 PM   #7
The house I live in 1913.. when it was built nothing would have had a trap besides the building trap.. and no vents either.. if you don't have a trap you don't need a vent Combination system too..
The drain is deep too about 6' deep inside
ShtRnsdownhill likes this.
Old 02-05-2020, 04:43 AM   #8
3rd year apprentice
View goeswiththeflow's Photo Album My Photos
Why is it that I always learn so much more here from the guys in the field, than I do from some office jockey writing a generic article with terms that no one uses, and using a photo of a guy who can't even be neat with the purple primer?
jeffreyplumber and skoronesa like this.
Fighting the good fight, piping the good pipe.
goeswiththeflow is offline   Reply With Quote
The Following User Says Thank You to goeswiththeflow For This Useful Post:
jeffreyplumber (03-10-2020)
Old 02-05-2020, 07:42 AM   #9
A drainage system doesn’t need vents to drain water and waste.
Toli is offline   Reply With Quote
Old 02-05-2020, 11:19 AM   #10
you answered your own question...." office jockey" NOT A PLUMBER".....ill bet whoever writes the articles just googles and then puts an article together...
maybe they should ask the members what to write..if for nothing else it would have a high overtone of blue collar humor in it.....
to whoever writes the articles......this is a tough crowd, and if you are going to act/pretend/think you know what your writing and not really know the trade out in the field...these are the responses your gona get.....
chonkie, skoronesa and Tango like this.
