Control Stop on the fly - Plumbing Zone - Professional Plumbers Forum
Like Tree19Likes
Old 07-29-2018, 11:39 AM   #1
View NyNick's Photo Album My Photos
Default Control Stop on the fly
Have any of you changed a Sloan Regal or Royal control stop out without shutting the supply off? I now work in a hospital and to my suprise valves are few and far between. I cant even stick my head up into the cieling to find one because removing a tile requires about 3 meetings, 2 hours of paper work and air testing...its a big deal and coming from working in construction is really frustrating. An example would be using my screw driver to turn off the stop and the stop breaking and springing a leak flooding out patient room because nobody can get to a shutoff valve. Id rather have a small flood than a big flood so Any tips, tricks, advice?
NyNick is offline   Reply With Quote
Old 07-29-2018, 11:48 AM   #2
Alan's Avatar
I've never had the supply stop break and cause a massive leak. Worst case was that turning it off resulted in a significantly reduced flow and I was still able to make the repairs to the flush valve and then mop up the water from the floor, but made a recommendation to replace the supply stop at the convenience of the business for ease of future repairs.
I understand in a hospital that may be difficult still, but I would imagine they would have some sort of maintenance team that should have some idea where shutoffs are located.
sparky likes this.
Journeyman Plumber
Old 07-29-2018, 12:04 PM   #3
Fatpat's Avatar
View Fatpat's Photo Album My Photos
A rule of thumb for my small company is to know how and where to shut the water off before any work is started.
Before I started my own company, I worked for the government for 2 years and understand the frustration.
You can make it a personal rule to have a latter, a few empty buckets & maybe a valve hook(piece of half-inch conduit bent into a hook 5 to 7 feet long ) with you before starting even the easiest of jobs.
Fatpat is offline   Reply With Quote
The Following User Says Thank You to Fatpat For This Useful Post:
sparky (08-12-2018)
Old 07-29-2018, 03:18 PM   #4
I have changed many main line valves on the fly up to 1 inch, after that the water pressure and volume is just to much to handle, but this has been done in open basements or crawl spaces where any amount of water will do no damage, now in a commercial building with multiple stories where flood damage could run into the tens or hundreds of thousands of $$$..I would want to know where the shut off valve is and make sure it worked before I started any repairs..
Old 07-29-2018, 03:21 PM   #5
chonkie likes this.
89plumbum (07-30-2018)
Old 07-29-2018, 03:25 PM   #6
The seals wear out and when you turn the screw water drips from the screw and in worse cases shoots out from the screw no matter if its turned off or on. The problem is compounded because its a hospital. Water on the floor could cause slip n falls and the time it takes to find a valve could cause a lot of water to fill the patients room. Its a state hospital...nobody wants to do anything or buy anything which takes forever to procure. The house "plumbers" which i am now one of have set up things and hold things secret (like valve locations) to ensure job security. Not installing valves also adds to job security ie...Overtime. I am new here and not used to working like this. I was wondering if I got a leak i could maybe disconnect flushometer from the stop maybe add a hose and hope the water would take path of least resistanse through the hose dumped into drain buying enough time to change the broken stop valve....I dunno. Im coming from union construction and have not had to deal much with service n repair work until now. Sooo any tips or thought are appreciated..thanks
Old 07-30-2018, 10:44 AM   #7
Alan's Avatar
Sadly, because they are angle valves, the path of least resistance is straight out into your face, not through the flush valve.
Not only that, but I try to be gentle with those stops when I change them, if I have to change to body, because most of the time they are just screwed on to a soldered fitting, and with the sleeve there, you can't hold it with a tool.
Another reason i'd want the water off before screwing with the stop.
I've had them drip before, but sometimes you can rotate em 1/4 turn left or right and they will stop. Never had one shoot out into the room uncontrollably.
Journeyman Plumber
Old 07-30-2018, 10:49 AM   #8
There should be a set of valves in the ceiling, wall, etc. to shut off areas without interfering with the whole building. Most codes require it.
Look for obvious panels.
Old 07-30-2018, 10:52 AM   #9
Alan's Avatar
Originally Posted by ShtRnsdownhill View Post
I wish I could see what the fk his actual problem was.
But upstairs in an apartment building without the water off? hahahahahhaha what a sucky day for that dude.
Journeyman Plumber
Old 07-30-2018, 11:18 AM   #10
I worked at the casino for a year as a 2nd year apprentice doing plumbing maintenance full time. There weren't many valves to shut down the line and fix a faucet for example. It was a nightmare, my mechanic would swear up and down searching for nights 1,2, 3! (we were working nights) to find a valve. Renting a scissor lift up to the ceiling 40 feet in the air, looking in dead space shafts using gang planks to try and access a valve hoping its the right one and usually it wasn't it. Many times we'd put a bucket in the ceiling tied with wire to catch the drip so they could use the black jack table during the day because we wouldn't have time to drain the system and repair.
Last summer at a hospital, the guy that does maintenance assured the plumber I know (just recently finished his 4th year apprenticeship) the water was shut off. He proceeded to cut a 4" copper water main with a sawzall. Flooded 3 floors, shut down surgery and several rooms. Several millions in damages. A year after that I worked for that same company, the plumber left to work with another company. What a stupid boss owner(Another story and my last boss ever!!)
What I'm saying do it on the fly and watch the millions go out the window and you may go to jail because of criminal negligence. Your reputation as a dumba$$ will follow you for life.
mtfallsmikey likes this.
The Following 2 Users Say Thank You to Tango For This Useful Post:
mtfallsmikey (07-30-2018), ShtRnsdownhill (07-30-2018)
Stop & Post A Picture Of Your Work Truck Fatpat General Plumbing Discussion 80 06-01-2019 10:59 PM
What are the best/shortcut ways to stop water wastage at taps due to leak? quickplumb General Plumbing Discussion 2 05-09-2017 03:10 AM
ABS Fitting Quality Control futz Plumbing Material and Products 5 12-17-2016 07:25 PM
How do i stop emai notifications from threads i post in BOBBYTUCSON Site Help and Suggestions 7 11-14-2015 09:03 AM
