Backflow (1/2" Watts 009QT) spraying water from the top - Plumbing Zone - Professional Plumbers Forum
Like Tree23Likes
Old 03-04-2020, 12:54 PM   #1
View Expo Engineer's Photo Album My Photos
Default Backflow (1/2" Watts 009QT) spraying water from the top
I'm relatively new to the world of backflows having just completed my tester certification course last year. I have a 1/2" Watts 009QT RP assembly that is spraying water from the little nipple in the middle of the top cap above the relief valve piston. I opened it up, found a broken piston O-ring (the red one that goes on the plastic piston itself). I replaced that O-ring but it still sprayed water. I then bought a relief valve rebuild kit and installed it but the same thing is happening. Is the little nipple on the top of the cap supposed to be open (air vent, etc)? If so what seals it so it doesn't spray water? There's also a slight dent in the cap below one of the 4 slots at the bottom of the cap (I have no idea how that happened). Could that be causing the leak? I tested this device 4 months ago and it tested ok. Help!
Expo Engineer is offline   Reply With Quote
Old 03-04-2020, 12:58 PM   #2
do a proper intro on your qualifications to be on this forum or you will get NO answers and your balls broken....
mtfallsmikey and skoronesa like this.
Old 03-04-2020, 01:36 PM   #3
mtfallsmikey's Avatar
View mtfallsmikey's Photo Album My Photos
Yes, please do an intro. I see you're a building engineer, like me, but I'm a 3rd gen. plumber first and foremost.
mtfallsmikey is offline   Reply With Quote
The Following User Says Thank You to mtfallsmikey For This Useful Post:
Tommy plumber (03-06-2020)
Old 03-04-2020, 01:42 PM   #4
You will need to fill in an introduction
Are you an employee, apprentice, journeyman, business owner?
Tell us if you had to go to trade school. How long?
How many hours or steps(1/2/3/4) before you become a journeyman?
What trade certificate do you have, plumbing, gas, oil, pipe fitter etc? How did you get them, exams, courses, or free in a cracker jack box?
What about your recent jobs, describe what you actually do and what type of building : houses, high rises, commercial building, institutional, oil refineries, paper mills etc.
Tell us about you, some funny plumbing jobs and or horror stories.
Intro page :
https://www.plumbingzone.com/f3/
breplum (03-05-2020)
Old 03-06-2020, 09:39 AM   #5
Alan's Avatar
And BTW I contacted Watts tech support to get the answer to my original question and reason for coming to this forum. Turns out that the 009QT RP should have been installed with a check valve to prevent downstream hammering. Wasn't actually a problem with the device.
I certainly wouldn't be one to argue with WATTS, but it seems kind of crazy to me that you would need to add another check valve to a device that already has two in it. If you have a water hammer issue wouldn't you install a device to manage that symptom instead of just putting something in front of the RPZ to keep it from 'seeing' the water hammer?
I might be misunderstanding the actual problem anyway.
ShtRnsdownhill likes this.
Journeyman Plumber
Old 03-06-2020, 05:27 PM   #6
Per the Watts tech I put in a $66 (from $Fergu$on$) spring check AFTER the device. He was thinking the fast closing water solenoid in the ice machine was causing the problem. It seemed ok initially but today I checked and it's still leaking. Back to square 1. I'm gonna go through another RP test procedure to make sure the internal checks aren't fouled. I would think if one of those checks is bad it would leak all the time. I have other backflows in the same area & they don't do what this one is doing.
Old 03-06-2020, 06:54 PM   #7
The check valve for a supposed to stop a water hammer and a sudden spike in pressure. This will cause the relief to spit but not the relief vent to leak. You’re getting water on top of the diaphragm some how.
Toli is offline   Reply With Quote
Old 03-07-2020, 11:26 AM   #8
How much water is this thing using that the solenoid closing does that? Maybe throttle the valve down before the backflow preventer just to add some restriction, might help with the water hammer.
Sounds to me like you need an expansion tank/hammer arrestor. Just throwin that out there since check valves usually make water hammer worse and hammer arrestors are designed to limit water hammer.
Or maybe the pressure is too high and you need a prv. I usually suggest one if it's over 90. I don't like to see pressure over 75 but trying to get my manager to push one on them when it's under 90 is like pulling teeth, he just doesn't see it as that much of a benefit and doesn't like to push them.
Expo Engineer (03-09-2020)
Old 03-07-2020, 04:34 PM   #9
did it spray from the time you put it in? or is it an older existing unit?
Old 03-09-2020, 01:38 PM   #10
The weird thing about this situation is, as far as I know, it just started spraying from the vent only recently. I think the ice machine and the backflow have been in place for over 15 years. When I first looked at it I found the red O-ring broken, replaced that with same results. Also same results after replacing the relief valve piston. There are other devices on the same water feed and they're not having any issues as far as I know. Per the gauge on the filter assembly the water pressure is 80-85psi.
