Water source HVAC & Hot water problem - No one could fix for 3 years... - Plumbing Zone - Professional Plumbers Forum
Like Tree3Likes
  • 3 Post By Tango
Closed Thread
Old 02-21-2019, 11:41 PM   #1
tts
View tts's Photo Album My Photos
Default Water source HVAC & Hot water problem - No one could fix for 3 years...
- Cross posting at **********************************
Hello,
I'm a home owner of a town house in San Diego, CA who is having terrible issue for multiple years.
I will really appreciate if someone can give any kind of advice on this.
Here the problem goes.
Facts :
The house has 'AO smith GPVT 50. Build date 1/21/2015' water heater in garage.
The water heater is also used for HVAC. I believe it's called water source HVAC.
The water heater has a pipe to the HVAC and the pipe has value so I can open/close.
Problem (short version) :
If I open the value furnace works so air vents blow hot air BUT all water taps/shower in the house lose hot water. It drops to ~85F within a minute or so even when furnace isn't running.
If I close the value furnace won't work so no hot air BUT we get hot water. Hot water temp stays very stable.
Longer version :
I bought and moved in 2016.9 and very soon noticed that there is problem with hot water.
I called plumber A - A said there is no problem with heater. Just crank up water heater setting.
The issue prolonged so I called another plumber (B), (B) found the value and closed and said he doesn't know what it's for.
At this time I didn't know this will stop the furnace. It's San Diego so we never used furnace..
In 2017.11 we moved out and rent the house out.
Tenant soon reported furnace isn't working in 2018.1. of course.
So I called another plumber (C) and explained the problem.
(C) installed a check value on one of pipes above the water heater and then problem disappered!
In 2018.12 there was an water leak incident in one of show so plumber (D) fixed water leak and did build back.
(D) changed shower value inside the dry wall.
After fixing the water leak tenant is reporting the hot water problem again and closing value give them hot water back.
Called plumber (E) he changed shower catridege in whole house but didn't help.
Called water heater expert (F) he said there is no problem with wather heater but said there is problem with water source HVAC.
Called water source HVAC expert (G) he now says there is no problem with HVAC but he think water heater needs more power.
I think there is no problem with water heater. As soon as I close the value the water temp goes very high.
So I wonder if there is cross connection within the HVAC or some flow problem..
Any thoughts? Or anyone in San Diego area can help fix this?
So far 7 different plumbers/HVAC guys couldn't fix for 3 years.
Thanks!
The value on the top left is the one I open/close.
I don't know what the top right one is (what is it?) but that's the one (C) installed check value.
Bottom right is the cold water inlet pipe.
tts is offline
Old 02-22-2019, 07:42 AM   #2
PlumbingZone is a site for Plumbing Professionals only, who are interested in promoting and improving the Plumbing trade. In our community the term "Plumbing Professional" refers to the following persons:
Master Plumber, Plumbing Contractor, Journeyman Plumber, Pipe Fitter, Apprentice Plumber, and Plumbing Helper, Plumbing Inspectors and Plumbing Engineers.
Plumbing Business Owners and Operators including management positions and their support staff. (Operations Manager, Service Manager, Project Manager, Superintendents, Customer Service, etc.)
Drain Cleaning, Fire Sprinkler, Hydronic Heating, Boiler, Steam, Chiller, Municipal Water and Wastewater, Potable Water Treatment, Septic System, Water Well, Wastewater Treatment.
The above outline is what we as a community consider to be a Plumbing Professional on the PlumbingZone. It was developed with input from a wide variety of our members that work in different areas of the trade.
If you do not see your particular aspect of the trade listed, but still consider yourself a Plumbing Professional, please send your request for inclusion to one of the Moderators via private message. Addressing this issue with individual members is to be done by the Administrator and Moderators ONLY.
As stated above PlumbingZone.com is designed to be a pros only community and that means that "Do It Yourself" homeowners looking for free advice and other non-professionals are not allowed to join the site.
GAN, OpenSights and Nazareth like this.
Tango is offline
The Following 2 Users Say Thank You to Tango For This Useful Post:
MACPLUMB777 (02-22-2019), Nazareth (02-22-2019)
Closed Thread
Water pH and Plumbing: Best Materials for Acidic or Alkaline Water Supplies PlumbingZone Featured Articles and Topics 4 07-30-2018 01:52 PM
Problem with water pressure. Well pump and tank. Need help jmw132001 Residential Plumbing 5 07-05-2017 10:13 AM
Strange Water Hammer dannyut General Plumbing Discussion 1 09-23-2015 04:15 PM
Low water cut off - why you need one nhmaster3015 Boilers, Hot Water & Steam Heating 13 08-21-2015 10:59 PM
