Sealed Sump Pump - Radon Unit - Plumbing Zone - Professional Plumbers Forum
Old 06-16-2015, 06:54 AM   #1
View ryanbe15's Photo Album My Photos
Default Sealed Sump Pump - Radon Unit
Hi everyone,
I'm a new home owner and would like to understand how to test my sump pump. Because our house has a radon unit, the hatch is sealed and thus i can't manually raise the float to force the pump to kick on. Also i only have one electrical cord coming from the pump. Attached is a picture of my sealed hatch.
The small tube is from the HVAC unit in the utility closet. That tube i can lift out of the hatch. What I've done thus far is I've poured about 8 gallons of water into the hole and the pump would kick on for about 10 seconds then quit. I have no idea how many gallons of water per hour the pump is capable of doing. I've done a bit of googleing and found that these sorts of pumps are pretty efficient and can move lots of water. So i just did a ball park guess based on some pumps I've found and said lets assume that this thing can move 2200 gallons per hour (which from what i can tell is a pretty small pump)...thus
2200 gallons per hours / 60 minutes = 36 gallons per minute
36 gallons per minute / 60 seconds = .6 gallons per second
8 gallons (amount i poured in ) @ .6 gallons per second = ~ 13 seconds
so it seems like it's working just fine. Given i'm a complete nub on this topic, figured i'd post and see if there was a better way of validating it's working.
Anyway, look forward to everyone's responses and guidance.
**NOTE the water in the top right of the picture has been fixed....durring the inspection the main water line was found to have a crack in it and was fixed by the homeowner**
**Also note the people who did the inspection stated that they could not test the pump because they had no access to it because it was sealed**
Best,
Ryan
ryanbe15 is offline   Reply With Quote
Old 06-16-2015, 07:57 AM   #2
Rexticle's Avatar
View Rexticle's Photo Album My Photos
I'd call a plumber or head over to diychatroom. You won't get any help here.
Rexticle is offline   Reply With Quote
Old 06-16-2015, 08:26 AM   #3
Michaelcookplum's Avatar
View Michaelcookplum's Photo Album My Photos
Validate it's working? You dumped water in and it turned on and then turned off.
Mike Cook
Michaelcookplum is offline   Reply With Quote
Old 06-16-2015, 08:51 AM   #4
plumbdrum's Avatar
Bye bye
Old 06-16-2015, 08:57 AM   #5
Gargalaxy's Avatar
View Gargalaxy's Photo Album My Photos
The PZ is for Plumbing Professionals ( those engaged in the plumbing profession).
Gargalaxy is offline   Reply With Quote
Old 06-16-2015, 09:32 AM   #6
Master Plumber
plumberkc's Avatar
View plumberkc's Photo Album My Photos
There is no way to really test a Sump pump, the units usually fail intermittently. If it's more than 7 years old just replace it.
plumberkc is offline   Reply With Quote
Old 06-16-2015, 07:58 PM   #7
Back in the game at last!
mrjasontgreek's Avatar
View mrjasontgreek's Photo Album My Photos
My thoughts exactly. Also you dumped in 8 gallons of water, pump ran for 10 seconds. I think that equals 48 gallons per minute, because math.
mrjasontgreek is offline   Reply With Quote
Old 06-16-2015, 08:32 PM   #8
AWWGH's Avatar
View AWWGH's Photo Album My Photos
Float operated sump pumps are one of the most complex areas of plumbing. From the electric motor, impellers, all the way to the float operated switch.
Since you seem helpless let me give you some solid insight, if you are worried about your pump have a plumber replace it. If you are not worried replace it when your basement floods.
AWWGH is offline   Reply With Quote
The Following User Says Thank You to AWWGH For This Useful Post:
mrjasontgreek (06-16-2015)
Old 06-17-2015, 11:54 AM   #9
Thank you for some of the advice i have received. I ended validating that it works by pouring water into the well and seeing the water escape from the corrugated pipe outside my house. What through me off was how efficient these things are. It was capable of getting ride of a lot of water in a short period of time. I will be closing this thread. Have a good day
Old 06-17-2015, 05:44 PM   #10
Don't you dare close this thread! That would take away the moderators chance to kick you out of here for not being a plumber!
The Following 3 Users Say Thank You to mrjasontgreek For This Useful Post:
Gargalaxy (06-18-2015), plumbdrum (06-17-2015), plumberkc (06-18-2015)
Sump Pump Michaelcookplum Plumbing Pictures 2 02-25-2015 07:04 PM
Sump pump ? leakfree General Plumbing Discussion 7 06-06-2013 09:14 PM
Sump Pump danfan13 General Plumbing Discussion 10 04-09-2011 02:49 PM
Sump pump DUNBAR PLUMBING General Plumbing Discussion 2 06-13-2010 10:46 PM
Outside Sump Pump Song Dog Plumbing Material and Products 7 07-25-2008 11:53 AM
