Mystery water heater problem - Plumbing Zone - Professional Plumbers Forum
Like Tree1Likes
Old 09-21-2015, 02:26 PM   #1
View Johnny Canuck's Photo Album My Photos
Default Mystery water heater problem
I've got a friend with 2 water heaters, side by side but not connected. Ones for the upstairs apartment, one for the downstairs apartment.
A couple of weeks ago his downstairs water heater started blowing off at the T&P so he had a guy in to replace the water heater and add an expansion tank. New tank, same problem so he replaced the T&P twice, same problem. Called GSW they said change the thermostats. He called me to do that. Same problem. Got GSW to agree to a new tank. I installed it, put the expansion tank on the cold supply instead of the hot that the other guy put it on. Just got called and it's still repeatedly blowing off.
My first thought was PRV but the house is at a constant 60 psi and the other water heater is fine.
Am I missing something?
Johnny Canuck is offline   Reply With Quote
Old 09-21-2015, 05:22 PM   #2
760GWS's Avatar
View 760GWS's Photo Album My Photos
Temp, pressure or defect...pick one ;-)
760GWS is offline   Reply With Quote
The Following 3 Users Say Thank You to 760GWS For This Useful Post:
plumberkc (09-21-2015), Redwood (09-22-2015), thumper (09-24-2015)
Old 09-21-2015, 05:48 PM   #3
View justme's Photo Album My Photos
Well if it's doing the same thing with the new heater that it was with the old heater then you have another issue and more than likely you're getting a pressure spike . I would get a tattle tell gauge to put on a hosebib near by and see what it spikes at. I call them a tattle tell gauge because they have a red needle that will show what the highest pressure the line has been exposed to while you're not looking , the red needle will stay at the highest pressure achieved even after the spike corrects itself. Good luck.
justme is offline   Reply With Quote
The Following 4 Users Say Thank You to justme For This Useful Post:
KoleckeINC (09-22-2015), sparky (10-04-2015), Zombie808 (10-06-2015)
Old 09-21-2015, 06:22 PM   #4
beanburner
View beanburner's Photo Album My Photos
check valve on the cold side .set the expansion tank lower than the pressure coming in to the house
beanburner is offline   Reply With Quote
Old 09-21-2015, 07:23 PM   #5
I checked again and it was up to 80 then down to 70 a few minutes later.
Old 09-21-2015, 07:28 PM   #6
Never seen anyone around here use a check valve.
Old 09-21-2015, 08:11 PM   #7
Cajunhiker's Avatar
View Cajunhiker's Photo Album My Photos
Would one or more water hammer arresters do the trick?
"So, I am to receive thirty percent for finance, for legal protection and political influence. Is that what you're telling me?" - The Godfather, Licensed Master Plumber
Cajunhiker is offline   Reply With Quote
Old 09-21-2015, 08:22 PM   #8
View bct p&h's Photo Album My Photos
Is there already a PRV? Either way, looks like you're buying one. When you do put it in, don't be cheap, install a gauge after it.
bct p&h is offline   Reply With Quote
Old 09-21-2015, 09:24 PM   #9
760GWS's Avatar
WH ea for US & DS apts, but common cold supply? If so, I'm thinking need the large exp tank, assuming 30+gal WHs.
Is that other TNP valve old and stuck closed? Might need to put a gauge on ea WH to compare.
Old 09-21-2015, 09:50 PM   #10
Master Plumber
plumberkc's Avatar
View plumberkc's Photo Album My Photos
That's a sure fire way to have your expansion tank fail in under 3 years.
plumberkc is offline   Reply With Quote
The Following 2 Users Say Thank You to plumberkc For This Useful Post:
Redwood (09-22-2015), sparky (10-04-2015)
exploding on demand water heater robertmilo1 Residential Plumbing 14 08-29-2015 04:46 AM
Low water cut off - why you need one nhmaster3015 Boilers, Hot Water & Steam Heating 13 08-21-2015 11:59 PM
Check Into Cash water heater plumberkc Business, Marketing, and Sales 11 08-16-2015 10:10 PM
Tankless water heater vent material question. snyper1982 Residential Plumbing 11 08-08-2015 06:15 PM
Water Heater repair starts apartment fire plumberkc Boilers, Hot Water & Steam Heating 13 08-02-2015 09:29 PM
