How to fix an American Standard Faucet - Plumbing Zone - Professional Plumbers Forum
Like Tree12Likes
Old 09-28-2018, 09:43 PM   #1
Default How to fix an American Standard Faucet
In order to fix a leaking American Standard Faucet on a roman tub this is what you have to do. It was installed 4 years ago.
Leaking diverter, remove spout....Ok it worked, the store gave her an incorrect longer stem...I swapped the o-rings. Turn the water on, no leaks until called 40 minutes later and her ceiling is wet. So I look at her instructions sheet the spout shank has O-ring under the tub...Great Impossible to get to!
The second complaint the handles were were opening the wrong way. The instruction says to turn the escutcheon and pull on the handle....Handles seized after 4 years of installation...Great!
So today I repaired the faucet completely as if it was new. All you have to do is cut a hole in the tile skirt and few maneuvers to to get to the shank O-ring.
chonkie, Debo22 and MACPLUMB777 like this.
Tommy plumber (09-30-2018)
Old 09-28-2018, 09:44 PM   #2
Got to go back on monday so I'll take pics of the repair. Did I ever say this brand sucks? On second thought, I hope I get more of these if you know what I mean...
MACPLUMB777 and Mikeob1998 like this.
Old 09-29-2018, 12:37 PM   #3
I just have to say they don't make stuff like they used to.
I've repaired tons of american standard faucets/tub valves. Sometimes yeah they get abused and let to leak longer than they should and then they are seized and difficult to disassemble.
I wouldn't call the brand junk though.
chonkie and skoronesa like this.
Journeyman Plumber
Old 09-29-2018, 01:45 PM   #4
I am not a fan of American standard at all. I would take it over some of the big box stores brands like p-fister. I much prefer Moen and if I get a call for a leaky faucet and it's an American standard I would offer to repair it but also tell the customer that it can also be replaced with a new and better faucet if they so choose. If it's a box store brand I get called out for I immediately tell the customer that it's going to be replaced unless they want to deal with the headache of finding parts and doing it themselves
Old 09-29-2018, 09:14 PM   #5
View fixitright's Photo Album My Photos
Drain cleaning is much easier. Sometimes.
czplumbing and skoronesa like this.
fixitright is offline   Reply With Quote
Old 09-29-2018, 11:59 PM   #6
Journeyman Plumber
Old 09-30-2018, 09:52 AM   #7
Job like those I get home so god damn tired I had to lay down. I even overslept 2 hours on saturday morning.
I'll take pictures next time to show how many tools and stuff to swap one out.
Old 09-30-2018, 10:06 AM   #8
KOLHER SUCKS !!!!!..it looks good and will last if you dont use it, but they suck every way it can..lol...
Old 09-30-2018, 10:33 AM   #9
I replaced that faucet with a Moen she bought. First time its one of those you have to solder the parts. It was easier than those freaking flex hose in a tight space and where stubs can never be tight and after a few month everything is loose and wobbles.
I still have to go back though, the pyramid escutcheons/handle assembly are just screwed in place by hand and you can turn them easily. The woman says they are loose and is scared water will drip under them into the main floor. I told her if I put them tighter the square radius will scratch the tub, but she's the customer!
I will be siliconing them tomorrow EVEN Though I did like the instruction that said to put silicone on the washers under the tub which I think is intended create a water seal. I'll do the same to the spout.
Should I put putty instead of silicone on top of the tub and underneath the escutcheons? Silicone may make them hard to pull out in the future. (putty might shear out when turning the escutcheons/handle assembly into place)
Old 09-30-2018, 06:34 PM   #10
Seems like nowadays everything in terms of trim kit is coming with it's own o-ring or built in foam gasket.
I also can't stand that square crap for that reason, and I also do not like mounting tub trim to the fiberglass. :(
I would do whatever the mfg suggests and CYA.
Journeyman Plumber
American Standard widespread faucet ID help spamispeople General Plumbing Discussion 0 04-06-2018 09:57 AM
Strange American Standard fill valve MECH-MAN Residential Plumbing 1 04-29-2017 12:50 PM
American standard "double vision" Plumbersteve Plumbing Pictures 16 01-22-2016 04:15 PM
American standard dclarke General Plumbing Discussion 33 11-23-2015 11:46 PM
Help! Old American Standard Tub Handle Plumber General Plumbing Discussion 7 08-10-2015 11:47 AM
