Heat tape / Heat Wire - Plumbing Zone - Professional Plumbers Forum
Like Tree21Likes
Old 10-04-2019, 03:56 PM   #1
Default Heat tape / Heat Wire
Anyone do heating wire around water pipes under a permanent mobile home? If it's just a plug in an outlet and safe sure I'll do it but I'm wondering if I should take the job or tell the customer to call an electrician.
On second thought I saw a video a house burned down because of that. Not worth the risk.
sparky likes this.
Old 10-04-2019, 04:08 PM   #2
View powellmatthew76's Photo Album My Photos
Never seen that before
Sent from my SM-J737V using Tapatalk
powellmatthew76 is offline   Reply With Quote
Old 10-04-2019, 04:10 PM   #3
yes I have a rental mobile home upstate and it has heat tape wrapped around the water lines...and plugged in with a thermostat that turns it on when it gets close to freezing..use a quality product( if you can find one nowadays) and every electrical device has the potential for fire...
sparky, BC73RS, skoronesa and 1 others like this.
BC73RS (10-04-2019)
Old 10-04-2019, 04:40 PM   #4
I've done it a few times. As long as you do the job correctly there should be no more of a fire risk than installing any other electrical device. Don't cheap out on the product and follow the directions. It would be like not doing water heater replacements because houses have blown up from incorrect installations.
I get my heat tape from Ferguson where they sell it by the foot. I forget what brand it and the thermostat are but I haven't had an issue yet.
sparky, skoronesa and MASTRPLUMB like this.
Old 10-04-2019, 07:40 PM   #5
View MASTRPLUMB's Photo Album My Photos
I have done it a few times in early 2000's In Washington State,
No losses that I know of, what else are you going to do in freezing weather
MASTRPLUMB is offline   Reply With Quote
Old 10-04-2019, 07:42 PM   #6
Get the electrician to put it on, he can take the blame if it catches on fire. I have a soap opera life. I better not do it.
Old 10-04-2019, 07:49 PM   #7
Talking
When you have just finished running a new water service, you don't tell
a customer that they have to wait a couple days without water till can
get a electrician to wire in a heat tape,
The only reason I would wait is if they did not have a good electric plug
for the heat tape
Old 10-04-2019, 08:26 PM   #8
I have always used Raychem self regulating heat cable. Brilliant design and bulletproof. I do the install and let an electrician make the connection.
BC73RS and alson like this.
The Following User Says Thank You to dhal22 For This Useful Post:
MASTRPLUMB (10-04-2019)
Old 10-04-2019, 08:44 PM   #9
I just told the customer some plumbers did but I wasn't doing it. Maybe it would be a good idea to have an electrician check the outlets and check the existing heating wire. That mobile home was a flip and I fixed a frozen pipe that wasn't repaired.
Old 10-04-2019, 11:21 PM   #10
BC73RS's Avatar
View BC73RS's Photo Album My Photos
On the bigger jobs I've done Raychem was always spec'd. We did all the wire wrap then handed the "Controller" to the sparky and they took it from there.
BC73RS is offline   Reply With Quote
