Cut the thread on steam radiator pipe, is it still ok? - Plumbing Zone - Professional Plumbers Forum
Closed Thread
Old 08-17-2015, 02:33 PM   #1
View Sirveu's Photo Album My Photos
Default Cut the thread on steam radiator pipe, is it still ok?
Hi All,
Since I was remodelling a little and removing the radiator to paint it, I also decided to change a very old and worn out radiator valve and remove some very incorrect connection angle pipes.
See here... http://screencast.com/t/iYTW7pz8
I ended up cutting the valve off because it was almost impossible to unscrew. The problme is that I some a tiny bit of the thread and worried that the steam radiator may now leak due to this.
See pictures here:
1 - http://screencast.com/t/bQVWBgkH2
2 - http://screencast.com/t/5jDzlJq4q
3 - http://screencast.com/t/RJkTatq0
4 - http://screencast.com/t/9pGRaGdNo
5 - http://screencast.com/t/etw2n97f
The new valve screws on perfectly well and I was told in hardware store that a slightly damaged thread is not a problem if I just put on some of the plumbing tape and the plumbing putty on it. However, they did not see the pictures above so I was worried what their idea of "damaged" is.
Will the putty and tape combination be fine or will it leak now or something?
I don't know what to do now as my home project keeps getting bigger and bigger by the day. If there is 90% chance that this will be fine, I would leave it and just make sure to tape and putty enough.
My other, very time consuming and expensive option is to buy a pipe threader and make the thread about an inch lower. Then cut the top part off. The good part about this is that I may not need to put much under the radiator to lift it up to the thread. I really hope not to use this option because if I mess up again, I may end up having to remove the floor to change the entire pipe under it.
What do you think?
Thanks!
Sirveu is offline
Old 08-17-2015, 02:36 PM   #2
mccmech's Avatar
View mccmech's Photo Album My Photos
I'm sure the guy at the hardware store gave you excellent advice! I would fly with whatever that person told ya. Fill the system, oh, and then call a REAL plumber to fix it when it fails!!!!!!!;-) ;-)
"If everybody says you're wrong, you just might want to reconsider".
mccmech is offline
The Following 2 Users Say Thank You to mccmech For This Useful Post:
chonkie (08-17-2015), GAN (08-19-2015)
Old 08-17-2015, 02:38 PM   #3
mccmech's Avatar
Oh, and just because I am a curious fellow, how did the "qualified" hardware store employee define slightly damaged?
mccmech is offline
Old 08-17-2015, 02:42 PM   #4
plumbdrum's Avatar
plumbdrum is offline
The Following 5 Users Say Thank You to plumbdrum For This Useful Post:
chonkie (08-28-2015), GAN (08-19-2015), Redwood (08-18-2015), Tommy plumber (08-18-2015)
Old 08-17-2015, 02:44 PM   #5
The person I talked to at the hardware store wasn't a real employee just looked like a contractor buying plumbing supplies for some job. Regardless of what he said, I obviously did not just go with it, hence me doing further research on here.
I don't know how the putty or the tape works well enough when it starts to impact to know if that damage would mean anything.
Very much interested in you opinion on what you would do in this situation with the thread issue I pictures.
Sirveu is offline
Old 08-17-2015, 02:45 PM   #6
mccmech's Avatar
Party Pooper!!!! He obviously has a radiant heat issue, not forced air. Exterior atmosphere is not gonna solve the problem. :-) ;-)
mccmech is offline
The Following 4 Users Say Thank You to mccmech For This Useful Post:
chonkie (08-17-2015), plumbdrum (08-17-2015), Redwood (08-18-2015)
Old 08-17-2015, 02:47 PM   #7
mccmech's Avatar
Well, firstly, my research would have revealed, to ME, that this is a forum for professionals only. Based on the results of my research, I would have moved on to a DIY forum! Let me ask you, what is your degree in?
mccmech is offline
The Following 3 Users Say Thank You to mccmech For This Useful Post:
chonkie (08-17-2015), GAN (08-19-2015), plumbdrum (08-17-2015)
Old 08-17-2015, 02:56 PM   #8
Hmm, okay, thank you for your very in-depth advice. I do appreciate the slickness of telling me to "get out of here noob" without actually saying it in such a way.
I wonder what you talk about on here since, according to your logically, the answer to every single question should be "Why don't you just call a qualified expert in that field?".
Anyway, you can pat yourself on the back because now I super duper want to call a plumber over and hope one with an attitude like your shows up
Sirveu is offline
Old 08-17-2015, 03:05 PM   #9
mccmech's Avatar
And I still wait, holding breath, to hear what YOUR area of expertise is. Don't go getting all cocky now, since ya got slapped on the nose for not paying attention to site rules. I'm guessing your field is one of a superior nature, that feels anyone else's rules are mundane & beneath you. Soooo, I really gotta know what major you received your degree in?!!!!!!!!! I won't be able to sleep without an answer! Please, please tell me.
mccmech is offline
The Following 5 Users Say Thank You to mccmech For This Useful Post:
GAN (08-19-2015), plumbdrum (08-17-2015), Redwood (08-18-2015), Tommy plumber (08-18-2015)
Old 08-17-2015, 03:21 PM   #10
plumbdrum's Avatar
I thought it was easier to show him the door, but this is just as ammusing
The Following 3 Users Say Thank You to plumbdrum For This Useful Post:
chonkie (08-28-2015), GAN (08-19-2015), Tommy plumber (08-18-2015)
Closed Thread
The Random Oops Video Thread... Redwood Off Topic (Non Trade) 0 08-06-2015 06:37 AM
