Cleaning propane torch nuzzle - Plumbing Zone - Professional Plumbers Forum
Like Tree18Likes
Old 09-13-2019, 09:30 AM   #1
View VictorPlumber's Photo Album My Photos
Default Cleaning propane torch nuzzle
Hello all:
I use Bernzomatic TS8000 torch for my work.
I always cleaned torch nuzzle from solder drips using coat hanger wire having fear of damaging swirling membranes inside.
How do you guys clean your torch nuzzle ?
Thanks
VictorPlumber is offline   Reply With Quote
Old 09-13-2019, 10:07 AM   #2
chonkie's Avatar
Not trying to bust her balls here, but in 15 years I have never had to clean a nozzle from solder drips. How close do you get with your torch? I've never had to get so close the solder drips in the nozzle. Also using the correct amount of solder so it sucks into the joint and doesn't drip should help the issue.
The Following User Says Thank You to chonkie For This Useful Post:
Tommy plumber (09-13-2019)
Old 09-13-2019, 10:54 AM   #3
Mine is full of solder drips.
Doing repair work - Often soldering/unsoldering inside the walls - have to keep torch close to joint so not to get house on fire.
Thanks.
Old 09-13-2019, 11:42 AM   #4
chonkie's Avatar
Do you not use a flameguard blanket when soldering in walls? I've used the Millrose ones for awhile and they do a great job, definitely recommended if you haven't used them before. I'm usually having to deal with not starting a fire inside expansion foamed walls.
Old 09-13-2019, 12:16 PM   #5
Thanks.
gently heat the nozzle till the solder melts then whip it to fling the molten solder out...if the solder is lose and can pass out on its own then your method is good..
dhal22, Debo22, skoronesa and 2 others like this.
Old 09-13-2019, 03:08 PM   #6
Thanks
Old 09-13-2019, 03:48 PM   #7
That's the way to do it BUT ............. you should also tell them to un-screw the nozzle from the torch first and hold with a pliers to gently heat it.
Without taking the nozzle off the head of the torch you run the risk of destroying the self light feature. Believe me there is not much difference from solder melting and burning off the spark wires. Been there done that!
dhal22, skoronesa and MASTRPLUMB like this.
Old 09-13-2019, 04:11 PM   #8
true, as I did say heat gently..LOL...and you dont want the torch tip connected to a propane bottle as you do this either..BOOM could result..
Old 09-14-2019, 10:53 PM   #9
Iíve had a ball of solder in mine for years, when I turn my torch upside down to solder a joint the flame gets funky. I shake it a little and the flame goes back to normal. One of these days Iíll try and get it out or buy a new one. Iíve had this torch for 25 years so itís my old faithful and I donít want to get rid of it.
Old 09-15-2019, 04:06 PM   #10
You can disassemble a good portion of it and you can get rig of solder. DO NOT try to disassemble the knob that shuts of the gas. I tried and I found out it's factory assembled. Once you take it apart you break it for good.
You can however dissemble the internal parts of the turbo tip where solder gets stuck.
