Long story short.
Roof top boiler. Mechanical guy had to relocate about 50 feet from plan.
Boiler, and closed loop has 3/4 inch relief valves.
Boiler drain is 1 1/4.
Is it better to run a 2 inch line, 90 up to a receptacle? Or run seperate, boiler drain, boiler relief, closed loop relief?
Per plan I have installed a roof receptacle that has a 2 inch dam, and a 3/4 make up protected by a rpbfp.
Or run all seperate lines?
Never run into a situation like this in all my years.
Thanks in advance.
Warning:
The topics covered on this site include activities in which there exists the potential for serious injury
or death. PlumbingZone.com DOES NOT guarantee the accuracy or completeness of any information contained
on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling
task!
Wow. First take a step back. If you installed per the "Approved Drawings", I would not alter it without a "Licensed Design Professional" (Architect or Engineer). Most locations an alteration without an approved change of work order leaves you in a position you don't want to be in.
If no drawings were provided and this is an as-built situation, there is still a question. For instance if this was just a swap out form an old to new unit (without a set of drawings) you have more leeway. To me in (Illinois) a condensate type drain is not required to terminate into a receptor on a roof. It can discharge on a roof and evaporate or run to scuppers. Since your looking at a temp issue, you need a receptor to deal with heat.
I would cut into the roof an install a floor sink, trap & vent it next to the unit. Then run all indirect into it. You mention an R.P.Z., not knowing you location. We are mandated to install those not more than 5" AFF, unless there is a walkway and discharge the relief onto a floor (providing a FD is in the same area) or indirect into a receptor.
Not knowing you area installing on outside I hope your not in an area subject to freezing, unless you utilize a hot box. Or install within the building mech room and run the line clearly marked non-potable water.
I do whenever I hear the ceol mor, the "great music" of the Highland bagpipe. I swear upon the holy iron of my dirk that I will not forget.
