Nervous..... - Plumbing Zone - Professional Plumbers Forum
Go Back   Plumbing Zone - Professional Plumbers Forum > Plumbing Tools, Products & Safety > Trucks, Vans, and Trailers
Like Tree29Likes
Old 02-10-2020, 01:58 PM   #1
Default Nervous.....
Well today started out as a pretty good day. I had three drain calls and my Master had two. One of his canceled until tomorrow, the other one canceled till next week, so all my Master did was drive me around in his truck for my jobs. We got back to the shop, loaded my machines on my truck and took off.
Half way home all of a sudden I lost power! Engine is running fine, but I had to floor it to get moving after a stop sign. I got it home and looked around, no leaks (outside of what you’d expect for a ‘97). I checked the trans fluid, not running, and only saw a drop on the end....
So I’m hoping it just low for some reason. Need to run out later for a few things. Transmission fluid is top priority.
Old 02-10-2020, 05:14 PM   #2
Could be simple as a bad alternator that's going bad, did the light dim? Is there a volt meter reading 14 volts in the dash?
OpenSights likes this.
Old 02-10-2020, 05:45 PM   #3
Unfortunately with tranny fluid by the time it affects the torque converter you've already gotten a bunch of wear damage from stuff not being lubricated. Ask me how I know twice over If the leak isn't big enough that it was obvious than you've probably been doing damage for a while.
Survey says; SELL IT.
Old 02-10-2020, 06:08 PM   #4
I got back from the store, started it up and the level was low, but not below low. So I added half a qt, shifted F to R for a few minutes. Tried to check the level again, but there was too much fluid in the tube to tell. Took it around the block and it drove normal.
Vacuum line maybe? Once it heats up it acts up? Wouldn’t surprise me for a 23yo truck.
Old 02-10-2020, 06:37 PM   #5
thats a tuffy to figure out not being able to see with your own eyes...
Old 02-10-2020, 06:55 PM   #6
I didn’t have my lights on so no dash lights. As soon as it started acting up I turned the radio off, so not sure.
No idiot lights came on, all gauges were normal.
Old 02-10-2020, 07:05 PM   #7
Lot's of things can be a culprit so start with easy stuff like clean the Mass Air Flow sensor, that can cause the truck to have a stalling effect. You may even have to replace it. It happened on my GF's car and my old work van, I cleaned it and helped and soon it started to act up again, the truck would just stall on start up. I replaced it and the truck was fine again.
What about the ground of the battery, clean and tighten.
Vaccuum : use propane on all the lines while the engine is running and if the engine revs you found a leak.
Old 02-10-2020, 08:26 PM   #8
I think you meant hear it with your own eyes. If seeing is believing than with vehicles hearing is knowing.
Ever met a guy who could tell you what's wrong by listening to the sound and counting beats per minute?
Old 02-11-2020, 12:45 AM   #9
well I assumed if one was there seeing it with their own eyes..their ears would be along for the ride so you can hear what may also be wrong..yes you are correct..hearing is as important as seeing whats wrong...
Im not a big fan of doctors, they call it the practice of medicine because they dont really know, so they are always practicing to see or hear what happens when they give you some drugs with wild side effects that most likely will kill you worse than the issue you are taking them for...
Old 02-11-2020, 07:42 AM   #10
I need a new truck too.... my 1997 ford e-350 is rusting out
and I have had to patch the floor boards under both drivers and passengers
seats with water heater flu pipe and expansion foam just to firm it up.....
once it starts to nickle and dime you to death, its time to put it down....
