Guessing wrong sized vent - Plumbing Zone - Professional Plumbers Forum
Old 08-01-2015, 08:25 PM   #1
AKdaplumba's Avatar
View AKdaplumba's Photo Album My Photos
Default Guessing wrong sized vent
In the mech room is a boiler and HWT totaling 100BTU. The C vent where the 2 connect is covered in rust and a white chalk. the B vent is 5'' while the C that connects to the B is with a 5x4x4 tee. The length is about 30 ft. I think the B vent should be 4'' all the way to the top. Since I don't have a code book on hand does that sound about right?
3 Laws for success:
Out wit
Out last
Out plumb
AKdaplumba is offline   Reply With Quote
Old 08-03-2015, 11:23 PM   #2
BC73RS's Avatar
View BC73RS's Photo Album My Photos
I just checked my BC code book and for two or more appliances at 30' the common vent can be 4".
BC73RS is offline   Reply With Quote
Old 08-05-2015, 11:20 AM   #3
View Catlin987987's Photo Album My Photos
When you see bad venting when connected to a boiler, I always check to see what temp the boiler is running. If its too low condensing, it always rots out the venting. Atmospheric boiler should always be set so min 130F return temperature.
Everyday Normal Plumber
Catlin987987 is offline   Reply With Quote
Old 08-06-2015, 02:24 AM   #4
Otobeme's Avatar
View Otobeme's Photo Album My Photos
Post a picture. Heat will not cause rust. Chemical reaction of combustion onto zink. If the flue is cold (winter) and hit with heat it will cause condensation. Check the cap on the roof has not been blown off and what Cat said. Make sure CO detectors are in place and functional.
How much horizontal venting? fresh air for combustion is good?
Otobeme is offline   Reply With Quote
The Following User Says Thank You to Otobeme For This Useful Post:
plumbdrum (08-06-2015)
Old 08-06-2015, 07:08 AM   #5
plumbdrum's Avatar
Originally Posted by Otobeme
Post a picture. Heat will not cause rust. Chemical reaction of combustion onto zink. If the flue is cold (winter) and hit with heat it will cause condensation. Check the cap on the roof has not been blown off and what Cat said. Make sure CO detectors are in place and functional. How much horizontal venting? fresh air for combustion is good?
Bingo
Old 08-09-2015, 03:26 PM   #6
AKdaplumba's Avatar
It looks like a straight vertical shot to the roof. It's a duplex, the other unit of the duplex doesn't have the problem and I am assuming it's done the same way.
3 Laws for success:
Out wit
Out last
Out plumb
