Cross over valve - Plumbing Zone - Professional Plumbers Forum
Like Tree7Likes
  • 2 Post By chonkie
  • 1 Post By PLUMBER_BILL
  • 1 Post By chonkie
  • 2 Post By Debo22
  • 1 Post By chonkie
Old 02-23-2018, 08:34 AM   #1
View geofd's Photo Album My Photos
Default Cross over valve
I was on another forum and this term came up I have not heard
of this..... I do alot more commercial stuff this was used in a home
domestic water heater with a pump in a home
geofd is offline   Reply With Quote
Old 02-23-2018, 09:15 AM   #2
View WashingtonPlung's Photo Album My Photos
Maybe you should explain what this valve does. Becuase i'm sure some of us have heard it by another name.
Is it a mixing valve?
WashingtonPlung is offline   Reply With Quote
Old 02-23-2018, 10:38 AM   #3
chonkie's Avatar
Probably referring to recirc system with no dedicated return line, the little block that's installed at the farthest point from the w/h, usually a lav, and it allows the hot to use the cold line for return to w/h. Grundfos has one you install the pump on the w/h and add the block.
Debo22 and MACPLUMB777 like this.
Old 02-23-2018, 11:20 AM   #4
Chonkie way back ... early 2015 this was a pretty big discussion.
Here is what I said then.Originally Posted by Best Darn Sewer
All this is news to me. I never knew the Grundfos comfort system bypass had a thermal control valve. Even when I've spoken with tech support in the past they just said its a simple check valve. Are y'all sure its thermally controlled? Being the timer on the unit controls the pump why would it be thermally controlled?
The timer on the pump is to turn it on lets say 6:45 A.M. and then turn if off lets say 9:39 A.M. Pump can be turned on and off according to life style. Control valve shuts off when hot water detected at faucet.
The Following 2 Users Say Thank You to PLUMBER_BILL For This Useful Post: Best Darn Sewer (10-04-2015), chonkie (10-09-2015)
chonkie likes this.
MACPLUMB777 (02-23-2018)
Old 02-23-2018, 01:29 PM   #5
I read that when there is no return for domestic he
there is a fitting that's installed under a lav (I don't know
how to post pics) when the pump on the water heater is on
it turns part of the cw into a hot return/as soon as a fixture is
used it shuts down that valve and it goes back to it origanal state
I will get the name of the one I found and post it
check out ready temp.com
Old 02-23-2018, 02:27 PM   #6
chonkie's Avatar
I remember that discussion. After taking one apart and testing it, we did conclude that it is not just a simple check valve and it actually closes off when the h2o reaches a certain temp. Don't know what the temp is but it happens.
Here's a pic of the block I'm talki ng about geoff.
Old 02-23-2018, 04:48 PM   #7
Thanks chonkie....
that was something else I was wondering thanks for all the info!!!!!
Old 02-23-2018, 05:08 PM   #8
Grundfos comfort system, it's designed to shut off at about 105 degrees. I got a call a few years ago where the homeowners complaint was when she turned cold water on at kitchen sink it was hot for about 2 minutes. A new bypass valve solved that problem.
chonkie and MACPLUMB777 like this.
Old 06-07-2018, 08:36 AM   #9
chonkie's Avatar
Originally Posted by anytimehvac View Post
A crossover valve is basically a defective or faulty mixing valve that allows cold water into the hot water pipes and/or hot water into the cold water pipes. This type of mixing valve is usually found wherever a hot and cold pipe meets at a fixture in a central heating system.
Next post of yours needs to be an intro. And how is a valve that is designed to allow hot water into the cold side "basically a defective or faulty valve"?
Old 06-07-2018, 10:19 AM   #10
Talking
Default Why Post An Intro?
An intro is requested from all new members. In case you missed it, here is the link. https://www.plumbingzone.com/f3/.
The PZ is for Plumbing Professionals ( those engaged in the plumbing profession)
Post an intro and tell our members where you are from, yrs in the trade, and your area(s) of expertise in the plumbing field.
This info helps members who are waiting to welcome you to the best plumbing site there is.
We look forward to your valuable input.
Jerry Mac
MAC SALES 777
832-409-5850
[email protected]
Delta shower valve has no pressure The Dane Residential Plumbing 32 03-08-2018 11:41 PM
Moentrol with 3 function transfer valve trim? The Dane Plumbing Material and Products 2 01-20-2018 05:58 AM
Knife valve prior to backwater valve JohnnieSqueeze General Plumbing Discussion 1 12-03-2016 08:02 PM
Cross Connection Bill Residential Plumbing 10 02-04-2016 02:48 PM
Tub/Shower Valve Installation Snowyman800 Plumbing Pictures 30 01-09-2016 02:17 PM
