Washer drain: FOAM/SUDS!!!! HELP!!! PLEASE!!! - Plumbing Zone - Professional Plumbers Forum
Old 02-04-2016, 09:20 PM   #1
View trickle's Photo Album My Photos
Default Washer drain: FOAM/SUDS!!!! HELP!!! PLEASE!!!
Had a call on what I thought was a backed up Washer drain.
We thoroughly augured / cleaned the 2 inch ABS line.
The drain takes all the WATER from the washing machine with NO PROBLEMS.
At the very end of the spin cycle the drain hose from washing machine produces a LARGE AMOUNT OF FOAM AND SUDS. It is at this time when the 2 inch riser overflows with SUDS/foam. (((NO WATER))))... The drain has discharged all of the water with NO PROBLEMS....
The home owner says he is using the same detergent that he has used for the past 4.5 years. Same detergent same amount of detergent ,same machine...
Now we have soap suds party every time the machine hits the very end of the spin cycle..
THE LINE IS CLEAR, THE TRAP IS CLEAR. IT TAKES OUT ALL OF THE WATER WITH NO PROBLEMS,NO BACK UP.... ONLY SUDS/FOAM..HELP PLEASE
trickle is offline   Reply With Quote
Old 02-04-2016, 10:17 PM   #2
View Plumbducky's Photo Album My Photos
Video inspect the line, something is not right.
Sent from my XT1254 using Tapatalk
Plumbducky is offline   Reply With Quote
Old 02-04-2016, 10:52 PM   #3
View Workhorseplmg's Photo Album My Photos
What did you auger the line with and what did you pull out?
Workhorseplmg is offline   Reply With Quote
Old 02-04-2016, 10:57 PM   #4
Mark
KoleckeINC's Avatar
View KoleckeINC's Photo Album My Photos
We had a soap suds problem from a 3 compartment into a 4" hub drain. Overflowed with Suds every time the sink was filled. I always assumed the wall mounted soap mixer was bad but never convinced the guy (subway restaurant owner) to try and change it. How much soap are they using may I ask?
KoleckeINC is offline   Reply With Quote
Old 02-05-2016, 06:24 AM   #5
Rexticle's Avatar
View Rexticle's Photo Album My Photos
How long is the stand pipe that the washer discharges into? Here in Canada it has to be minimum of 24" from hose to trap.
Something does seem fishy tho. Why the problem now and not 4 years ago. You may not be getting the whole story from the HO.
Rexticle is offline   Reply With Quote
The Following User Says Thank You to Rexticle For This Useful Post:
Jessedog11 (02-07-2016)
Old 02-05-2016, 07:40 AM   #6
Did they by chance put in a watersoftner because that would mean they now need less soap to do the same job which means now they are technically using too much soap.
The Following 2 Users Say Thank You to The Dane For This Useful Post:
[email protected] (02-05-2016), wookie (02-07-2016)
Old 02-05-2016, 07:42 AM   #7
I Married Up
plbgbiz's Avatar
View plbgbiz's Photo Album My Photos
I've seen this before. In my case it was the washer.
6 loads of hot water with a LOT of bleach cleaned out the soap build up in the washer and it went away.
The self-made man is just a boy that won't say who helped him.
Thanks Dad.
plbgbiz is offline   Reply With Quote
The Following 6 Users Say Thank You to plbgbiz For This Useful Post:
bulldozer (02-07-2016), cable or root (02-05-2016), gear junkie (02-07-2016), [email protected] (02-05-2016), sparky (02-06-2016), Tommy plumber (02-05-2016)
Old 02-05-2016, 07:46 AM   #8
They are over-soaping or else they need a new washing machine is what comes to mind for me. Maybe the machine is not getting all the soap out when it is supposed to come out; and the soap comes out at the end of the cycle from the machine producing too much suds in the pipe.
Is it a new washing machine? The newer machines discharge the water faster {I think} and if the drain line is only 2", that could be a problem. The current code here in FL requires a 3" stack with a 2" standpipe for new installs. Maybe they got a new machine recently and it's overloading their undersized piping. My 2 cents.
Old 02-05-2016, 08:07 AM   #9
I Married Up
plbgbiz's Avatar
Originally Posted by Tommy plumber
They are over-soaping or else they need a new washing machine is what comes to mind for me. Maybe the machine is not getting all the soap out when it is supposed to come out; and the soap comes out at the end of the cycle from the machine producing too much suds in the pipe....
That is exactly what is happening.
Thanks Dad.
Old 02-05-2016, 08:10 AM   #10
That makes perfect sense to me.
Watch out Drain Cleaning Buddys Roto-Rooter Drain and Sewer Cleaning 15 01-09-2016 12:16 PM
why dosent my shower drain kiddplum Plumbing Pictures 4 12-25-2015 05:34 PM
Can a macerating toilet drain into this pipe? eminn3m Residential Plumbing 18 10-15-2015 09:54 PM
Fort Worth, TX needs Drain Techs, Plumbers, and Apprentices kmedina Plumbing Jobs 1 10-09-2015 11:49 PM
Drain still clogged after being snaked. toysoldier Drain and Sewer Cleaning 20 10-09-2015 08:20 PM
