Sewer Lining CIPP - Plumbing Zone - Professional Plumbers Forum
Like Tree31Likes
Old 03-18-2020, 01:00 AM   #1
View Standard Drain's Photo Album My Photos
Default Sewer Lining CIPP
Just curious if anyone else here is doing any sewer lining?
Standard Drain Cleaning
Missoula MT
Standard Drain is offline   Reply With Quote
Old 03-18-2020, 03:49 PM   #2
Ridgid tool user
gear junkie's Avatar
Not this guy but I know enough that if I was to get into it, I'd be visiting the clog squad and take their class before making the investment.
Buy cheap, buy twice.
Old 03-18-2020, 03:56 PM   #3
I don't think it's legal in my area because you reduce the pipe size and that mean it's not to code. If it's not to code you're buying them new pipe when they sue.
Old 03-18-2020, 07:22 PM   #4
It's roughly a 3mm reduction depending on the liner used. Around here it's not permitted for interior piping; but they will tell you its a case by case situation.
Im sure we will have more established code soon enough.
Missoula MT
Old 03-18-2020, 08:25 PM   #5
A couple years back I used a sledgehammer to line a cracked 4" cast iron pipe about 13' long with 3" pvc from in the basement. Waste line and tank were under a pretty new, expensive deck. After the tree the rest of the waste lines were 3" in the basement. Only 1-1/2 baths.
A couple weeks ago I used a home made chain flail on a 3/8" rod to smooth a 5' piece of no-hub going through a foundation and then brushed abs glue on the inside. I replaced the no-hub tree with all pvc fittings at the same time. That last cast iron piece through the foundation is being replaced this spring. The line from the tank to the foundation was replaced a couple weeks ago.
No-hub cast iron is garbage, it rots quick(less than 20 years, sometimes faster), and it cracks easy. Also the 2-band connectors can pull off when the hangers come loose because the lazy cheap Ahole didn't use a back up nut.
I don't think either of these examples is what you mean though lolz
chonkie, Debo22 and MACPLUMB777 like this.
Old 03-18-2020, 09:06 PM   #6
I gota have some of what your smoking..................
MACPLUMB777 and Tango like this.
Old 03-18-2020, 10:35 PM   #7
Say what you want, by sleeving that line under the deck I saved them a ton of money. The top of the tank was 8' deep!!!!
And the second one was a stop gap. She has tons of money and "Just wants to be able to flush her phucking toilet without worrying it will overflow in the basement.". I can't blame her. After the third time in two months your basement floods with sewage you get nervous about going poo.
Old 03-19-2020, 12:14 AM   #8
this..............
Old 03-19-2020, 03:35 PM   #9
Alan's Avatar
Had to do that before on a complete dump of an add on where there was no crawl access below, and the add on was above the sewer line. Crawled under the main house, cut it off, cut off the connection outside, and slammed a piece of 3" pipe through it. It was only a 1 bath.
They would have had to completely gut the part of the house above the sewer line otherwise.
chonkie, skoronesa and MACPLUMB777 like this.
Journeyman Plumber
Old 03-20-2020, 08:56 AM   #10
Talking
I Have been holding out waiting to see what you guys were posting,
Back about 15 years I worked for a company that got into Lining
using the Perma-Liner brand of lining,
it was amazing to watch it work, it goes past holes in the pipe as while
as jumping across breaks in the pipe up to 2-3' ,
we did this by setting up a demo in our shop going around a 90 and running out
where we had cuts holds in the pipe and making breaks in it,
This was done with 4" SCH 40 pipe
this will work with smaller pipe,
https://perma-liner.com/
OF COURSE THEY ARE OTHER COMPANY'S OUT THERE MAKING PRODUCTS
Jerry Mac
MAC SALES 777
832-409-5850
[email protected]
