![]() We have 2 different locations that we have issues with sand in a main line, both are supermarket/large big box stores. Both are 4" lines which are about 1/2 or more full of sand over 200' length and ballpark 400'plus to exterior of building. Neither have 2 way clean outs outside...no need for those(sarcasm)...
We are going to try and forward jet the line out to the street, or at least as far as possible, then camera line to see how it looks. You guys have any other thoughts/ideas? Rooter just stirs it up and sand falls back to bottom of pipe. |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. PlumbingZone.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Sponsored Links | |||
Advertisement |
![]() A bit of advice... before you blow all that sand out to the city, give them a call. They will want to be there with their own jetter or vac.
I learned that with a bad grease line before. |
The Following User Says Thank You to OpenSights For This Useful Post: |
Ridgid tool user
![]() Good luck but don't expect great results. You need to pull all the sand in one direction. Pushing doesn't always work so well. Be careful.....sand is easy to get stuck in if you go to fast as the sand will settle behind your hose.
Buy cheap, buy twice. |
The Following 8 Users Say Thank You to gear junkie For This Useful Post: | cable or root (02-10-2016), celtic1 (03-02-2016), ChrisConnor (02-10-2016), Roto-Rooter (02-11-2016), saysflushable (02-11-2016), Shoot'N'Plumber (02-10-2016), skoronesa (02-22-2016) |
Advertisement |
![]() Agreed, will for one, the other runs to a lift station on the property(site owned) and will just go to the bottom of the pit where it can't hurt anything.
![]() can you get a vac truck and vacuum them out?
![]() Good point, go slow...will do, don't want to make a bad situation worse...
![]() Not logistically possible, too many things on line to cap off to create enough suction to pull sand out...
![]() Good luck, but they're probably screwed. With that much sand there's probably a lot of bad breaks. Don't get stuck. They may try to pass the blame off on you. Bottom line is they need serious repairs. If part of the line broke that bad there's likely going to be more breaks in the near future. My advice is to either cut your losses, or convince them to replace everything.
The Following 2 Users Say Thank You to cable or root For This Useful Post: | celtic1 (03-02-2016), MACK ATTAKK (02-11-2016) |
#9 | |
![]() Quote:
Old man used to say "assume responsibility or blame someone else", already blamed someone else and made that very clear.... |
The Following 2 Users Say Thank You to JimmyMac For This Useful Post: | dhal22 (02-11-2016) |
#10 | |
![]() Quote:
The Following User Says Thank You to ShtRnsdownhill For This Useful Post: |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Washer drain: FOAM/SUDS!!!! HELP!!! PLEASE!!! | trickle | Drain and Sewer Cleaning | 16 | 02-18-2016 04:56 PM |
Did a small drilling job 2" drain line take a look. | cjtheplumber | Drain and Sewer Cleaning | 28 | 02-16-2016 08:46 PM |
Watch out Drain Cleaning Buddys | Roto-Rooter | Drain and Sewer Cleaning | 15 | 01-09-2016 01:16 PM |
Drain material | moonapprentice | Drain and Sewer Cleaning | 17 | 01-01-2016 02:18 PM |
Drain still clogged after being snaked. | toysoldier | Drain and Sewer Cleaning | 20 | 10-09-2015 09:20 PM |
