I've got another kitchen sink line clogged this morning. I alway cut the pipe before the p-trap and start there. My K-45AF is starting to take a heavy toll on my shoulders and back holding that thing for almost 2 hours with a 5/16' 50' foot innercore cable in the drum. This line was full of 90's and jammed with grease, water started to go down after an hour and a half.
I was over 25 feet inside the pipe. 50% of the time the lines are clogged over 25 feet so my 25" cable stays in the truck. Its also a pain to put the cable back in the drum all tight and stiff. All the lines I clear usually take more than an hour so I'm dreading to hold that thing.
Either I make a stand to hold my pistol rodder or I order a sink drum for my k-3800. Ordering a sink drum would probably take 3-9 months to get one because no one wants to ship to Canada at a cost of over 600$ with a new cable . A drum machine would be impossible in some tiny bathroom I get sometimes.
I generally don’t use a drill for sinks, but when I do I hold it upside down and rest it on my knee so that my pinky is the trigger finger. It can still be fatiguing, but better than holding it like you would a regular drill.
Try a sink machine that's ergonomic......try the Ergo-Auger; compact, super versatile, zero pounds when in use, so easy a 45 lb child can demonstrate in real application, never buy another sink machine again!
One of my favorite applications. No need to get in tub to work, sit on side inserting cable using the pod to support on so your back won't hurt the way it does when using K-45.
I use a Ridgid K-50 for inside lines, like kitchen drain lines. The K-50 with a 5/8" cable {the flexible one, not the stiffer 5/8" cable} is a beautiful thing in a 2" kitchen drain line.
In my humble opinion, a 5/16" cable is undersized for a 2" line with greasy waste.
I have a 5/16" innercore cable in a small drum attachment that fits onto the K-50. But it is only for stuff like lav stoppages where the stoppage is in the p.o. assembly, p-trap or just past the trap.
For us kitchen and lav lines, bathtub, washing machine lines are 1 1/2". All I know 5/16" feels right but I'm not an expert yet, I have a 3/8 and its so stiff that I used it to clear a 3" a few months ago.
The new 2010 code has 2" for washing machine lines and for showers.
I'm thankful for the clutch in the k-45 so I can push through the 90's otherwise I'd be going nowhere.
Here's a quick prototype stand I made this afternoon. Dry fit until tomorrow. The top part are 1 1/2" pipe can can slide into the 2" and held with the flex coupling. I can adjust the height.
I hate pistol augers. I used one once a long time ago at a company and I thought that I had about 20' of cable in the drain line. But when I pulled the cable out, I only had gone in like 3' or 4'.......:vs_laugh:......another reason to love the K-50.
I don't know your budget, but for $1300 or so, you can purchase the K-50 with 5/8" cable and a small drum with 25' of 5/16" cable. Trust me, you won't regret a K-50 for kitchen sink drain lines.
I have {2} different temper 5/8" cables; one is stiffer and the other is a less stiff cable. Each has it's different use.
Does the K-50 drum have the capacity of 50 feet 5/16"? I love auto feed not sure if I'd like the k-50 pushing it in.
I was also suggested the ELECTRIC EEL CT, which seems pretty nice. Really nice actually.
In the mean time to decide which machine to buy, this morning I had another sink line to do. The clog was around 40 feet. The pipe ran into the exterior wall down to the rim joist then a back towards the front of the house, 2 more 90s to drop below the center beam and more turns after that. It was a battle, I had to use the clutch to push the cable every 6 inch after 30 feet of so. It was impossible to push it by hand.
Too bad redwood doesn't post anymore he had a k-3800 he could reply to this one easily, anyway I have a new 3/8" IW cable in the box for my k-3800 with autofeed. Ridgid site states it can be used for 1 1/2 lines. Will it work, with lets say 1x tee, 5x 90s or more? My extra drum is back ordered and If I switch out my 1/2 IC I won't be able to do main inside the house or toilet lines.
While I'm waiting for my K-3800 sink drum and cable to arrive in the mail I tried out my stand today. I installed a cleanout on the down pipe and went to town.
Anyway I modified my stand with protruding wheels on the bottom so I can move the pistol back and forth to play with the cable when needed.
This is the Cadillac now, It felt so comfortable not having to hold the heavy pistol with 50 foot cable inside the drum. This time the clog was around 37 feet. It was so easy to pull back and wiping the cable with two hands feeding it back to the drum.
I need to modify the stand leg for the undersink contraption, other than that I was happy to go to work today...awesome!
Hell, I just got the sink drum for the k-3800 after 5 months of waiting! 327$
General cable was 152$
Total : 479$ and people I get complain about the price on drain cleaning. I bet I'm the most equipped in my area by far.
The K-45 will take a rest while I try this out. Last time I used my k-45 the freaking screw that holds the drum started to pop out again. I'll stick to 25 feet in the pistol. Now thinking of it I'll leave the new cable in the bag and swap the used one from the pistol into the drum. Damn now I have a spare 5/16"x50' and a 35'x3/8" that doesn't work properly in the pistol.
Sure I get calls for sinks(last night, last week and today in an email, too lazy to call when I say to call) They expect free well I don't know. I'll try to remember to ask the next one if they expect a service for 12$ or something. Let them buy 4 bottles of vinegar and baking soda called draino and let them think it'll work.
I used to charge 45$ for for the use of the pistol and 75$ for the drum. Looks like sinks now are going to end up at 75$ for the tool use plus my hourly rate.
You sure are making me even more thankful I live in the US, dispite all the stupidity, political correctness and general lack of common sense we have to deal with.
You say that because the price I paid for the equipment or the delay to get it? There were no sink drum in the US or Canada for the past 5 months...It took almost 3 months to get the guide tube for the K-3800 That too was out of stock.
I gave ridgid crap about not having stock and derailed their new drain machine thread on their forum. I hope they heard me up to their offices.
I even told ridgid that if I knew they had such lousy service I would of purchased another brand. I even offered the members to buy my almost new machine at a loss so I could buy something else.
Can be expensive switching brands though. Run it till it eventually pukes and find a different flavor. I prefer spartan machines, but that’s me. Expensive, but do a good job.
I'm not sure how you guys do things in Canada, but at least one of those sanitary tees on that contraption are facing the wrong direction. :biggrin:
Looks nice. I might have to put something like that together when I get around to buying a snake. Got a bigger job today so maybe sooner than I think.
20.3K members
