Frozen PEX pipe burst. - Plumbing Zone - Professional Plumbers Forum
Like Tree13Likes
Old 03-02-2019, 01:04 PM   #1
Default Frozen PEX pipe burst.
This is the first time I see PEX burst because of frozen pipes. There was a house that lost heat with no one living in it. Toilet tanks were solid ice. There were copper in the mechanical room but PEX in the walls and stubbed out in copper. I thought PEX was pretty good at taking frost and I was hopeful that there might not be any burst pipes in the walls. There were 2 burst copper pipes and a cracked brass ball valve in the mechanical room. The kitchen had copper stubbed up through the floor and down about 10" in the ceiling before converting to PEX. When turning on the water we heard a leak in the ceiling under the kitchen sink and it turns out there were a burst PEX pipe both on the cold and on the hot line in the exact same spot basically. I'm thinking that PEX might be good at dealing with frost when it has enough pipe to expand but on short pieces like this it might not take frost too well. I also thought it was weird how the hot side has burst perpendicular to the pipe and not with the pipe like you normally see.
OpenSights, MACPLUMB777 and Tango like this.
The Following User Says Thank You to The Dane For This Useful Post:
Tommy plumber (03-03-2019)
Old 03-02-2019, 01:17 PM   #2
Venomthirst's Avatar
Your probably right short pieces like that with no expansion room.. if it's really cold and they have a tap open a wee bit I know the pipe won't burst if it freezes because it'll allow for expansion but even if it freezes in two different spots it could spell trouble.. thank the lord our frozen pipes have hopefully come and gone so far for this year I did about 50 frozen pipe calls and about 30 of them the pipes were split
Venomthirst is online now   Reply With Quote
Old 03-03-2019, 10:05 AM   #3
Dane, how deep are water services buried in your location? Where are you, Minnesota?
Here in FL, our code states 1 foot minimum for water services. But we have some services that are exposed on the outside of the bldg. and then turn with a 90 and go into the exterior wall. Hard freezes are not all that common here.
Old 03-03-2019, 10:26 AM   #4
I can never get used to hearing about things like water lines and water heaters outside the house. I believe the water service is a minimum of 7' below grade here. I have heard about frost as deep as 11' down. About 5 years ago here in town the city told people to run a constant drip to avoid freezing water service. It gets cold up here in north west MN. I think technically you are allowed to run water lines in an exterior wall if you take proper steps to protect it from freezing but normally no one would run a water line inside an exterior wall. It's around this time of the year I think about moving somewhere less cold. I'm getting tired of the snow and cold. Friday it heats up to a nice 25-30 degrees. Almost nice spring weather for around here.
Old 03-03-2019, 06:49 PM   #5
You guys must have a micro climate. It seems it colder where you are than up north where I am.
Tango is online now   Reply With Quote
Old 03-03-2019, 06:56 PM   #6
Well north west Minnesota is technically further north than quebec city Canada.
Old 03-03-2019, 07:05 PM   #7
Not by much, like I said previously I think it's colder where you are because of the wind of the great lakes.
Old 03-03-2019, 07:15 PM   #8
You could be right. What ever it is I'm getting tired if it and honestly would not mind moving to a milder climate. Not some place hot just milder.
Old 03-04-2019, 12:14 AM   #9
Talking
Here in Houston.Texas it is going to get down to a very cold
low to med 30's, come Monday night though Tuesday it will be down
into the low to mid 20's
Jerry Mac
MAC SALES 777
832-409-5850
[email protected]
Old 03-04-2019, 01:13 AM   #10
You guys donít do re-pipes/re-routes like this?
breplum, skoronesa and MACPLUMB777 like this.
The Following User Says Thank You to Debo22 For This Useful Post:
Tommy plumber (03-04-2019)
Condensate pipe query Mozziebear Plumbing Code 8 05-18-2018 08:56 PM
State of Chicago, question. . rjbphd Plumbing Code 4 01-12-2018 11:42 AM
Pipe burst 4" cast iron asapmarty Plumbing Tools and Equipment 3 08-16-2017 06:37 AM
Megapress- how clean does the pipe need to be. plungerboy Plumbing Tools and Equipment 26 02-01-2016 07:45 AM
Silverback Couplings for HDPE pipe burst gear junkie Drain and Sewer Cleaning 9 10-06-2015 01:42 PM
