Drain hose disconection (separated) in washing machine and water flooding - Plumbing Zone - Professional Plumbers Forum
Closed Thread
Old 04-03-2016, 02:00 AM   #1
View a_2008's Photo Album My Photos
Default Drain hose disconection (separated) in washing machine and water flooding
Hello everyone
I have a portable top loader washing machine 1.5 Cu. Ft. (Haier HLP23E),7 months ago ,connection hose between drain pump and drain hose separated and all water in tube came out and flooded my bathroom, it was terrible. I connected it again with spring hose clamp and a little adhesive and it was fine for six or seven month but again yesterday it separated from drain hose and hopefully this time water level was very low and I had a drain pan under washing machine so damage was nothing. Current problem is with connection hose when the machine was draining, water began to spew out of the under of the washing machine, connection drain hose that the machine's drain hose is hooked into. . It doesn’t get secure and will separated again and again if I don’t fix it essential Now I purchase a new drain hose and drain hose connection to replace those parts. Is there any Adhesive to use?
1. What Can I do to secure drain hose to avoid happening again since I’m in 3rd floor and high level of water will ruin all units?
2. Is connecting drain hose to pump with this hose clamp enough?
3. What Can I install between connection to stop coming out water rapidly? (Because when it disconnected and separated all 1.5 cu.ft. water comes out and all carpet gets dirty, I cannot stop it with turning off water since water is in tube)
I would appreciate your help.
First image is old and is before disconnection:
this time will use this clamp and replace drain hose
a_2008 is offline
Old 04-03-2016, 05:22 AM   #2
Hillside's Avatar
View Hillside's Photo Album My Photos
That sucks
Hillside is offline
The Following User Says Thank You to Hillside For This Useful Post:
Shoot'N'Plumber (04-04-2016)
Old 04-03-2016, 05:32 AM   #3
I've had good luck with JB weld
Debo22 is online now
Old 04-03-2016, 07:45 AM   #4
just use a good layer of silicone l, that will fix it all no problem..
ShtRnsdownhill is online now
Old 04-03-2016, 07:57 AM   #5
View Eric's Photo Album My Photos
You could use 3-M weatherstrip adhesive found at most auto stores, made to glue rubber parts.
or
Bellows adhesive, (Mercury / Quicksilver 92‑86166Q) made to glue rubber parts on boats and keep them from sinking.
What's the condition of the plastic piece the hose is clamped to? maybe it's crushing in and the reason the hose comes off.
Eric is offline
Old 04-03-2016, 08:51 AM   #6
sarcasm just goes over so many peoples comprehension......
Old 04-03-2016, 09:01 AM   #7
View Qplumb's Photo Album My Photos
Get thicker carpet, it will absorb more water. Also I see that in the first pic it has a red halo, maybe it's possessed
Qplumb is offline
The Following 4 Users Say Thank You to Qplumb For This Useful Post:
cable or root (04-04-2016), Drain Pro (04-03-2016), SHEPLMBR70 (04-04-2016)
Old 04-03-2016, 10:48 PM   #8
or
Condition is good , connection hose come off because there is not any tight clamp to keep that in place.
Any other suggestion?
a_2008 is offline
Old 04-03-2016, 11:08 PM   #9
better call a plumber....
Old 04-04-2016, 12:05 AM   #10
Doesn't sound like a plumbing issue, call a licensed appliance repairman.
The Following 4 Users Say Thank You to Debo22 For This Useful Post:
cable or root (04-04-2016), Letterrip (04-04-2016), Phat Cat (04-04-2016), SHEPLMBR70 (04-04-2016)
Closed Thread
