Ridgid tool user
![]() 6" clay pipe with a blocked drain and 10 root intrusions. On site for 30 minutes. Took 15 minutes to clean the pipe while sitting on the bucket. Tango likes this.
Buy cheap, buy twice. |
The Following User Says Thank You to gear junkie For This Useful Post: | Tommy plumber (09-13-2019) |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. PlumbingZone.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Sponsored Links | |||
Advertisement |
![]() Thanks for the interesting and informing videos you make.
I wonder how long you think such a typical sewer clog would take if you had to go in to the basement and put a drop cloth down do a tiny bit of cleanup and the time talking to the customer? I ask because if it does take 0.5-1 hour less than a big drum machine. Then I would like to hear if you think that set up with camera not being charged extra but just earning itself by jobs taking less time would maybe be worth the investment. So with a basement scenario do you think the time saved over a drum machine would be enough to make a camera investment pay for it self by gaining time not by selling a camera inspection? For a small company that does not specialise in drain cleaning so not getting used daily. I ask out of curiosity and because I would not mind if my current boss got a setup like that does not weigh so much. Our main service guy who does most of the drain and sewer calls has a bad back and I feel sorry for the guy when ever I hear that he has a sewer call and has to log around a heavy machine Sent from my BLN-L24 using Tapatalk |
Ridgid tool user
![]() How much longer would it take in a basement? How long does it take to walk to the basement? No idea but that I can legitimately carry that machine with 2 fingers. Now that job was a real legit job....had no idea how it was going to turn out and it was really easy. But the video with the Trident? Yeah my machine failed on that one....but so did 2 other plumbers and one of them had 4018 jetter. I ended up getting the roots out with my cable machine. Couldn't sit on the bucket for that one lol and had to send the cable in 4 different times 115' to try different cutter heads. Took almost 2-1/2 hours but not tired or sore at all, not working on my knees etc. Just gotta think outside the box.
Going back....you asked about the camera....if I didn't use the camera I would've saved about 7k from buying a camera BUT......BUT......I would've missed doing the repairs. Since I don't do sewer replacements, the homeowner called me about that job and said they found someone to do the replacement for 13k. Would you spend 7k to make 13k once? What about making 13k twice? Three times? Point is the cameras cost the most but in the right hands, they are the tools that will bring in the most profit. Just gotta know the right way to use them
The Following 3 Users Say Thank You to gear junkie For This Useful Post: |
Advertisement |
#4 | |
![]() Quote:
Actually for that amount, why don't you? Sent from my BLN-L24 using Tapatalk |
![]() If you're not running a camera before and after a jetting job or sewer cleaning then you don't know whether you cleaned the line properly. Without running a camera you're a clog popper not a drain cleaner. Just my 2 cents.
The Following User Says Thank You to justme For This Useful Post: | Tommy plumber (09-13-2019) |
#6 | |
![]() Quote:
I'm a clog popper and that's fine with me! I'll clean it at an extra cost but so far only 2 have accepted it. |
#7 | ||
![]() Quote:
A lot of them have had the line snaked multiple times before and never had a video inspection done. When they see how thorough I am they understand why I'm higher than a "clog popper" . I'm still less than the big guys with the snake and video, sometimes a bit over half their price. justme likes this.
#8 | |
![]() Quote:
Let's say charging an extra 50$(included in the tool fee) That would mean being able to use it 100x if it cost 5K to buy or 200x if it cost 10K. I doubt it would survive that much without repairs or replacing it. I have a lot of people not wanting to pay regular rate to unclog stuff so adding an extra 150-200$ to cover that tool might dwindle your clientelle to nil or almost nil. What do you think? justme likes this.
#9 | ||
![]() Quote:
If I'm going out just for a video inspection then I usually charge close to 3 times that. I figure if I'm already there and have everything set up for snaking then the camera is only another half hour tops. Plus there's the chance of getting additional work from it. Unless you get a crap camera, or you don't know how to run a camera, you should be able to get several hundred uses before you need to service or replace it. I have well over 500 uses on my current Ridgid seesnake and it's still in good shape. I don't use it to push objects, push through clogs or run it past suspect looking joints. That comes out to less than $20 per use. If you take into account the tens of thousands in excavation work it's helped me get then it's a no brainier. |
The Following 2 Users Say Thank You to V.A Hydro-ooter For This Useful Post: | dhal22 (09-12-2019), Tommy plumber (09-13-2019) |
#10 | |
![]() Quote:
Why oh why would you NOT want to know your effort's results? Use a camera!! skoronesa likes this.
Thread Tools | |
Display Modes | |
