Best sectional cable shown with the Dreel - Plumbing Zone - Professional Plumbers Forum
Like Tree3Likes
Old 03-02-2019, 03:00 PM   #1
Ridgid tool user
gear junkie's Avatar
Default Best sectional cable shown with the Dreel
Using the drill to highlight the strength of the sewer cable but recommend for the user to follow the safety instructions set forth by manufactures and their company policy. Use drill at YOUR OWN RISK!!
The General Pipe Cleaners 5R-10 is a 7/8x5' cable that works with the General RT-66, Ridgid K60SP, K5208 along with Rothenberger and any drain cleaning machine that use 7/8" sectional cable. The ends are compatible with the Ridgid T-slide blade holders as well.
Five foot lengths enable it to be used in a bathroom or tight places. Makes the sectional machine more versatile and easier to use. Highly recommended!!
Debo22 likes this.
Buy cheap, buy twice.
The Following 2 Users Say Thank You to gear junkie For This Useful Post:
Debo22 (03-02-2019), Tommy plumber (03-03-2019)
Old 03-02-2019, 03:20 PM   #2
Venomthirst's Avatar
Good video.. showing different options to get the job done thanks again for your contributions
Old 03-03-2019, 09:20 AM   #3
Thanks Ben for the video.
A couple of things to say:
1st the positive:
If, and I say if, the plumber was doing that job inside a home through the W/C riser pipe {least desirable method} I like the drill option since it is less to use inside a small bathroom. Also the shorter 5' cables are easier to manage inside a small space.
2nd the negative:
When you released the trigger on the drill, the cable turns 5-6 revolutions. I don't like that. Also, the user has to keep walking towards and away from the c.o. with his body instead of kneeling at the c.o. and feeding the cable in or out. Additionally, both hands are needed to operate the drill; I like to feed the cable in w/ {1} hand while my other hand is on the K-60 machine.
My other concern would be the power. The drill's power isn't evident from the video. Except what is telling is the thick roots that it pulled out. So it appears that the drill has some power. How it measures up to the power of a K-60 though, I can't gauge from the video.
The conclusion that can be drawn is that this is another tool in the experienced drain cleaner's toolbox. The drill option gives the drain cleaner another way that has its place in trying to clear a stoppage.
The 5' lengths of cable are definitely a good tool to have. The 5' cable may eliminate the need to use the sleeve that comes with the Ridgid K-60 machine kit. The plumber could feed in the 15' lengths of cable until the stoppage is encountered and then switch to the 5' lengths to minimize the excess cable flopping around outside of the c.o. My 2 cents.
The Following 2 Users Say Thank You to Tommy plumber For This Useful Post:
gear junkie (03-03-2019), rooterboy (01-09-2020)
Old 03-03-2019, 03:05 PM   #4
Ridgid tool user
Tommy, thanks for the comments.
I actually use that cable more with my k60 then with the dreel. Also I'd never use the dreel inside. Now General just came out with 1-1/4 x 5 sectional cables....oh boy...that changes a whole lot right there. Inside use, I don't use the guide tube at all. I just use carboard on the floor.
The drill is a makita mud mixer....the thing that separates it from every other drill I can find is it has a paddle switch so you can change direction on the fly. Also the drill weighs 8lbs and cost 140 so I don't care if it lasts a year. I use the same drill with 1-1/4 electric eel cable that has a 5/8 innercore and it works well. Just to give you a weight comparison...the electric eel is stored in 32' reels. The 7/8 general cable is stored in 75' reels. Can I fit more with the electric eel? Yup...just can't pick it up.
I like the dreel setup because my hands never touch a spinning cable....there's a picture of a freak accident where a plumber has a k60 cable right through his hand. Also the dreel setup is physically easier to use because I have back pain, a good weather and bad weather knee and my hands go numb from excessive vibration. The dreel eliminates all that.
I actually took all the 15' cables out the van and only have the 5'ers.
breplum (03-13-2019), Tommy plumber (03-03-2019)
Old 01-06-2020, 12:47 PM   #5
AssTyme's Avatar
View AssTyme's Photo Album My Photos
Eel has made 4' sections of 1.25 for years.
AssTyme is offline   Reply With Quote
Old 01-06-2020, 12:48 PM   #6
AssTyme's Avatar
You're welcome
Old 01-06-2020, 12:54 PM   #7
AssTyme's Avatar
I think I'm going to be purchasing some of these 5' sections soon. How many feet can you fit in one reel?
Old 01-06-2020, 02:58 PM   #8
Ridgid tool user
75'-90' AJ Coleman has them in stock.
The Following User Says Thank You to gear junkie For This Useful Post:
AssTyme (01-06-2020)
Old 01-07-2020, 02:34 PM   #9
AssTyme's Avatar
Going to get them from All Star for $38.55 each.
Old 01-07-2020, 02:35 PM   #10
AssTyme's Avatar
We talkin' flex shaft money here!
Choosing a Drain Cleaning System for Your Business PlumbingZone Featured Articles and Topics 5 06-22-2020 08:36 PM
Cable sizing for 4" Tango Drain and Sewer Cleaning 7 03-21-2018 09:08 AM
The newest sectional cable just came in!! gear junkie Drain and Sewer Cleaning 20 09-21-2017 11:26 PM
Sectional Cable Review is up!!! gear junkie Drain and Sewer Cleaning 11 02-04-2017 11:01 AM
7/8 vs 1 1/4 sectional cable? sullivanplumb Drain and Sewer Cleaning 26 02-06-2016 05:47 AM
