Any thoughts on the General Wire P-T3-D? - Plumbing Zone - Professional Plumbers Forum
Like Tree9Likes
Old 01-19-2019, 05:18 PM   #1
View PlumbdogTim's Photo Album My Photos
Default Any thoughts on the General Wire P-T3-D?
My plumbing supply stocks these for about $1150. You can't really find any reviews online anywhere for them, so does anyone here have any experience with this machine? What would you recommend in it's place?
Here is a link to it on Amazon.
https://www.amazon.com/General-Wire-.../dp/B009HX94BW
PlumbdogTim is offline   Reply With Quote
Old 01-19-2019, 05:37 PM   #2
View Standard Drain's Photo Album My Photos
What is the main type of blockage you are trying to work on?
If your looking for a 1/2 branch line; and the occasional main I had purchased
https://www.gorlitz.com//drain-clean...s/GO-50-PE.asp
Its pretty light to carry around.
If your looking for something to clear 4 inch mains I would get something thicker than 1/2 inch cable machine.
Standard Drain Cleaning
Missoula MT
Standard Drain is offline   Reply With Quote
Old 01-19-2019, 06:31 PM   #3
The T3 is only for 2"-4" and only up to 100' because it's only 1/3HP and on their site it states it's for inside drains so not good for tree roots outside the house. I have use their speedometer 92 for mains and it worked good.
If you are looking for inside the house then I would go with the rigid k3800 with a few desperate drums that holds different sizes of cables so you only need 1 machine for all sizes inside the house. If you are looking for main sewer machines I would go bigger. We currently use Gorlitz for main lines and it's powerfully as can be but a heavy beast and I would not buy it myself because of the weight.
Old 01-19-2019, 06:52 PM   #4
This machine would be for cleaning out sewer lines inside of a house. Probably mainly body wipes and stuff like that. I have a 1/4" machine for real small blockages. I figure a 1/2" machine is a good investment, the next thing I would need is a 3/4" for 6" mains and tree roots. 5/8" seems like an in-between size. I'm thinking that that would be the last addition unless you guys think that would be a better investment than a 1/2" machine.
I'll get some prices on the K-3800. The downside of it is that you get 10' less on 1/2" cable. Do you think it's a better machine than the T3? I read the cable isn't interchangeable between the two brands, is Ridgid cable notably better than the one General uses?
Old 01-19-2019, 09:00 PM   #5
I can't speak too much about the cables and have only actually tried running the k3800 1 time. You will find on here that a lot of people here can and will recommend the 3800. I will soon enough be buying the k3800 myself as I prepare to one day start my own business. I would get the sink drum with 1/4" cable for tub drains and old 11/4" galvanised drains. The 3/8" 75' drum for 11/2 and 2" drains. The 1/2" 75' drum for 2" floor drains and laundry drains and only 3"drain if I know it's inside the house so no roots. For sewers I would get a bigger machine and just have 5/8" 100' plus an extra 50'-75' drum if it is longer than 100'. 5/8" will do 6" but I have rarely seen a 6" sewer line, that tends to go to the rooter company that has the bigger equipment. Since its mostly 3"-4" we deal with for sewers I don't see the need to log around all that extra weight of a bigger cable when almost all our sewers are in basements. The 10' you loose is nothing to worry about unless you work on mansions, I have never had more that 50'-75'cable on any machine inside a house and rarely use more than 40' max and never have I been short of cable inside a house.
Old 01-19-2019, 11:02 PM   #6
Fatpat's Avatar
View Fatpat's Photo Album My Photos
In my opinion there is no need for 1/2” cable on residential systems. 3/8” can handle any branch line and the occasional “pair of underwear ” in a mainline. Duracable is my brand of choice my 3/8” & 1/4” machine is a DM138A2.
I run 5/8” rubber core for my mainline machine
Which is a Duracable Dm162. Two drums are necessary to give me 160’ of reach.
plumberinlaw and MACPLUMB777 like this.
Fatpat is offline   Reply With Quote
Old 01-20-2019, 05:25 PM   #7
an inner-core 3/8 might be ok for branch lines 2-3 inch. But I think for what he stated his need is; i would go ahead and grab the 1/2 machine.
Missoula MT
Old 01-20-2019, 06:07 PM   #8
Talking
https://www.electriceel.com/products...5-auto-feed-2/
Model Z5 Auto Feed
Cleans 1-1/4” – 3” diameter lines up to 100 ft. while running 1/2″ dia. galvanized aircraft wire inner core cable. Built-in drum shaft slip clutch. Upright frame on large 10” wheels with folding handle. Rear bar shields motor and allows for two position operation. Steel guide tube/inner drum. 1/2” x 75 ft. cable standard.
In addition to all the benefits and features of the standard Model Z5, the auto feed version allows the operator to advance and retrieve the cable with the push of a lever. The cable runs through a guide spring which keeps hands off the rotating cable for added safety.
Additional information
Cable Length
75ft.
Minimum Drain Size
1 1/4in.
Maximum Drain Size
3in.
Power
Electric
Power Details
1/3 HP
$ 1,300.00 FOB SPRINGFIELD,OH
:bigg rin:
sethro1981 likes this.
Jerry Mac
MAC SALES 777
832-409-5850
[email protected]
Old 01-20-2019, 06:28 PM   #9
Talking
http://www.trojanworldwide.com/colt.html
Trojan Colt Sewer/Drain Cleaning Machine with 1/2" x 75' cable, $237.00
http://www.trojanworldwide.com/Trojan-Colt-New.pdf $1,295.00
POWER FEED $495.00
RECOMMENDED 13/32" X 100' $244.00
This is the best can go anywhere a 3/8" cable will But also will do anything
that you would want to run a 1/2" cable I have over 25 years running this,
ALL THIS FOB HOUSTON, TEXAS
:bigg rin:
Jerry Mac
MAC SALES 777
832-409-5850
[email protected]
Old 01-20-2019, 09:54 PM   #10
I have that 1/2" and NEVER use it. When the other guys cover my calls they will bring the 1/2", not get the clog, and then tell the customer I will come monday with the "big snake". I use the 5/8" version. I think they call the 5/8" the speedrooter 92. I have two 5/8"x100 cables in drums and a 3/4"x75 in a drum. I also have a spare drive head. I use my 5/8" several times a week for 4" main line blockages. Having the spares is a must so you don't miss a call. The drive heads last about 6 months before being torn down, cleaned, and new bearings put in.
It has a lot of torque even though it's only 1/3hp. Occasionally(once or twice a year) I will run the 5/8" all the way out and then swap drums, connect cables, and run the 3/4" so I can get out even farther. I don't like doing this but for a good customer in a pinch I will. Usually I just tell them sorry call joe blow with the 600' jetter and the excavator.
It is alright going upstairs, easier than our ridgid/kollmann k-750 drum snake but mostly because the general is shorter. Both have stair rollers. For getting the snake back in my van I have a ramp and a pulley system. For years I used to just get in and pull it up myself but after a manhole cover broke my toe and it had to heal for a couple weeks I finally broke down and took the time to do something I have been wanting to do for years.
The guys on here mostly seem to like sectional and the ridgid drum units but personally I love my general snake, never lets me down. The general cables are great too and I recommend them regardless of what brand drum unit you get. General is first and foremost a wire and spring company. I wouldn't be surprised if they make other brands cables. Of course they keep the best alloy recipes to themselves.
https://drainbrain.com/en/products/speedrooter-92/
Get that guy^^ It won't let you down.
dhal22 likes this.
rooterboy (01-21-2019)
Your experience or thoughts on the General Wire JM-1000 mini jetter Tango Drain and Sewer Cleaning 55 05-17-2019 07:29 PM
Ferguson heaan Plumbing Material and Products 33 05-10-2018 12:27 AM
Need thoughts and suggestions on Jobs Reeder General Plumbing Discussion 15 09-20-2017 08:13 PM
Thoughts on dresser couplings on galvanized WashingtonPlung Commercial Plumbing 20 05-10-2017 09:39 PM
General Wire Drain Pro Drain and Sewer Cleaning 15 11-19-2015 05:10 PM
