canuckPlumBbob
![]() These comercial kitchen sink mounted faucets always seem to be loose and flopping around, decided to try some shower lock 90's today.
Worked like a charm nice an tight, only thing i found was the escushions dont sit flush to the sink cause of the lock 90. What have you guys done with these? MACPLUMB777 likes this.
The Following User Says Thank You to canuck92 For This Useful Post: | Tommy plumber (07-20-2019) |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. PlumbingZone.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Sponsored Links | |||
Advertisement |
![]() I like these flanges sink ell fittings with a close nipple nipple in faucet and through sink hole and then the sink ell nice and tight up against the backside of the sink It seems to work good. It's been a while since I did one and last time I used a big washer or 2 on the backside to make it work.
![]() Sent from my BLN-L24 using Tapatalk |
The Following User Says Thank You to The Dane For This Useful Post: | Tommy plumber (07-20-2019) |
#3 | |
![]() Quote:
The Following User Says Thank You to Toli For This Useful Post: | Tommy plumber (07-20-2019) |
Advertisement |
#4 | |
![]() Quote:
![]() This is an option.
https://api.ferguson.com/dar-step-se...UCT_ID=4040056 Here's another https://www.tsbrass.com/p/miscellaneous-parts/B-0426 |
Plumbing since 1974
![]() We use/stack large galv. Steel washers as spacers between the s.s. Splash and the brass fitting. Even a close nipple usually needs one or two
Sent from my iPad using Tapatalk
Marc Brenner Company Lafayette, CA 925 283-3408 |
![]() What he said
![]() and a drop of silicone between each washer helps keep it all together and from shifting when they bang big pots into the faucet..
You cant cure stupid, only kill it.. |
The Following User Says Thank You to ShtRnsdownhill For This Useful Post: | sparky (07-21-2019) |
![]() You could also use a 1/2" romex nut or cut the end off of a coupling.
. Tango and MASTRPLUMB like this.
Want privacy from the diy/hacks? Too bad, the motherland has fallen, freedom is dead. "I'd rather have Questions that can't be answered, then Answers that can't be questioned" |
![]() This and only this is what we use, made for the application:
https://www.tsbrass.com/p/parts-kits/B-0230-K skoronesa likes this.
The Following User Says Thank You to JimmyMac For This Useful Post: | Tommy plumber (07-20-2019) |
Thread Tools | |
Display Modes | |
