Question about water supply for tankless heater - Plumbing Zone - Professional Plumbers Forum
Like Tree1Likes
Old 10-22-2015, 01:02 PM   #1
GrtLksPlbr's Avatar
View GrtLksPlbr's Photo Album My Photos
Default Question about water supply for tankless heater
I'm looking for some advice.
I have a builder who has spec'd a tankless water heater for a new build and has asked me to come up with a way to raise the temp of the water going to the tankless in an effort to reduce the delta T for the purpose of being able to produce more GPM without going to a larger tankless water heater.
Our typical ground water temps are 48-50 F, so I usually calculate a need for a 70F heat rise to deliver 120F water, which is max per our state code.
The only way I can think of to bring up the water temp supply to the tankless without using a tank style water heater to partially heat it is to use a simple uninsulated tank so that the water can gradually reach ambient temp, at times of zero consumption of course. Under demand, the pre-"warmed" water supply will give out eventually. This just doesn't seem like a very good approach.
Using a standard water heater to pre-heat the water would be more effective, but I worry about the possibility of bacterial growth at the moderate temps the tank would be operating at. Not a good idea, either.
Another issue with this idea is that while reducing the delta T will help the tankless unit produce more GPM at a set temp, it's not really a huge jump in output, maybe getting me 7+ GPM.
Well, that's it in a nutshell. Any constructive ideas?
Thanks, Scott
GrtLksPlbr is offline   Reply With Quote
Old 10-22-2015, 04:39 PM   #2
View mugdiller's Photo Album My Photos
http://www.bing.com/images/search?q=...verlay&first=1
you can reclaim some heat from drain water, however I would recommend just bumping up a unit, or tying 2 together, I deal with the same water temps here. whats the peak GPM you are looking at
mugdiller is offline   Reply With Quote
Old 10-22-2015, 04:58 PM   #3
newyorkcity's Avatar
View newyorkcity's Photo Album My Photos
I think you answered your own questions in your post.
I downsize previously oversized space heating boilers regularly to serve the customer better.
Looking for a way to lower the delta T to avoid purchasing a larger tankless water heater is a different scenario and not a risk I would feel comfortable with.
I am not sure if the issue with not getting a larger unit is money, but it reads as if it is. If so:
I have started telling GC's that either they or the owner has to cough up the dough to do things right, instead of asking someone else to be the fall guy if things don't work out as planned. The same homeowners who cry that they are broke seem to find the money for the nicest granite and appliances.
newyorkcity is offline   Reply With Quote
The Following 7 Users Say Thank You to newyorkcity For This Useful Post:
760GWS (10-30-2015), dhal22 (10-22-2015), Phat Cat (10-23-2015), plumber joe (10-25-2015), Plumbus (10-22-2015), saysflushable (10-22-2015)
Old 10-22-2015, 07:18 PM   #4
Plumbus's Avatar
I'd tell your GC that I'm not a water alchemist. Changing the ΔT requires energy. The source of that energy boils down to $$$.
The Following 5 Users Say Thank You to Plumbus For This Useful Post:
dhal22 (10-22-2015), GrtLksPlbr (10-23-2015), Phat Cat (10-23-2015), Plumbdog (10-26-2015)
Old 10-22-2015, 08:39 PM   #5
Beautiful!!!!
The Following User Says Thank You to dhal22 For This Useful Post:
mtfallsmikey (12-01-2015)
Old 10-22-2015, 08:49 PM   #6
Cajunhiker's Avatar
View Cajunhiker's Photo Album My Photos
The simple solution is to add a second tankless to help with gpm demand if you increase the temp to 140 degrees, and to use quality units that have the recirculating pump built into them.
Benjamin1959 likes this.
"So, I am to receive thirty percent for finance, for legal protection and political influence. Is that what you're telling me?" - The Godfather, Licensed Master Plumber
Cajunhiker is offline   Reply With Quote
Old 10-22-2015, 09:01 PM   #7
Just tell him to find a way to get a btu to do more...
1 BTU=1 DEGREE FAHRENHEIT INCREASE IN ONE POUND OF WATER.
Surprise us all with his brilliance...
~Mark Twain~
The Following 2 Users Say Thank You to Redwood For This Useful Post:
Old 10-22-2015, 11:26 PM   #8
rwh
Redwood is right. I swapped out my 110volt baseboard heat for 220v. Twice as efficient
rwh is offline   Reply With Quote
The Following User Says Thank You to rwh For This Useful Post:
Old 10-23-2015, 12:50 AM   #9
You put it in better words than I did, you're dealing with a 90-94% efficient application, adding a tank is not an option
Old 10-23-2015, 08:20 AM   #10
GrtLksPlbr's Avatar
Thanks for the responses, guys.
This builder is one of those Mr. Wonderful types that is often clueless but believes that technology has an answer for everything.
I was pretty certain that there was no free lunch in this situation and your responses have confirmed that he's asking the impossible.
Hot water recirc question Michaelcookplum General Plumbing Discussion 36 01-24-2019 09:18 AM
Water heater expansion tank question please Gregplumb Residential Plumbing 4 10-13-2015 11:04 AM
Mystery water heater problem Johnny Canuck Residential Plumbing 30 10-04-2015 10:04 PM
Low water cut off - why you need one nhmaster3015 Boilers, Hot Water & Steam Heating 13 08-21-2015 10:59 PM
Tankless water heater vent material question. snyper1982 Residential Plumbing 11 08-08-2015 05:15 PM
