Introduction to PEX... - Plumbing Zone - Professional Plumbers Forum
Like Tree7Likes
Old 05-13-2016, 10:03 PM   #1
Blackhawk's Avatar
View Blackhawk's Photo Album My Photos
Default Introduction to PEX...
So a lot of cities are now allowing pex around the areas I work (Chicagoland area). I have zero experience running pex for domestic water. The supply house I primarily deal with sells Uponor brand pex.
I have been told that the Uponor system is a poor choice for areas with drastic climate changes, or areas that get really cold.... obviously this fits chicagoland.
Just curious as to thoughts on what is the best system for domestic water...?
Also how do you usually run the pex lines. I see some people build a manifold and run lines to each fixture individually. I also have seen people pipe houses like you would with copper or cpvc... run mains and branch off to fixtures.
Any help or information would be greatly appreciated.
Alice Bond likes this.
"Choose a job that you like, and you will never have to work a day in your life."
Blackhawk is offline   Reply With Quote
The Following User Says Thank You to Blackhawk For This Useful Post:
Master Mark (05-14-2016)
Old 05-13-2016, 10:57 PM   #2
In my oppinion Viega and their plastic fittings that comes with the stainless sleve already on the fitting is the top quality brand. At work we use copper rings on plastic fittings ( I don't recall the brand names). My first employer and my current employer both run a main trunk line and branch off of it so that is the method I use.
Old 05-13-2016, 11:30 PM   #3
Location: Southwastern Ontario the land of the wind turbines
View Dpeckplb's Photo Album My Photos
We use rehau and aqua something Pex. We still use the brass fittings with copper rings. The company I work for does main and branch Pex which for a small house is ok. I'd rather home run because there is only two joints to worry about.....well unless the drywallers go nuts.
Dpeckplb is offline   Reply With Quote
Old 05-13-2016, 11:30 PM   #4
View Plumbducky's Photo Album My Photos
I run the uponor system.
Also run it like copper
Sent from my XT1254 using Tapatalk
Plumbducky is offline   Reply With Quote
The Following User Says Thank You to Plumbducky For This Useful Post:
Debo22 (05-14-2016)
Old 05-14-2016, 12:50 AM   #5
wyrickmech's Avatar
View wyrickmech's Photo Album My Photos
We use uponor only. Expansion rings are the way to go. The issue with cold weather may be the expansion ring. In the winter we keep a heat gun handy to help speed the shrinking process.
wyrickmech is offline   Reply With Quote
Old 05-14-2016, 08:20 AM   #6
Flyout95's Avatar
View Flyout95's Photo Album My Photos
Blackhawk, don't do it, don't go pex! Come back to the big work!
Flyout95 is offline   Reply With Quote
Old 05-14-2016, 09:34 AM   #7
Just remember that most pexes will never look as good as copper....if you can get past that hurdle then you are good....
The best system is the wirsbo Uponor pex,, Just go out and buy yourself one of those small hand held Milwaukee expander kits ($300)
and you are good to go....
I have used the same tool for probably 5 years now....
Once you get the hang of it you can fly with that stuff...
You also want to use the black plastic fittings
You have been told wrongly about the climate issues with aquapex..
The wirsbo pex is also probably the most freeze proof on the market. I have seen whole houses done in wirsbo pex that were totally frozen solid and nothing broke..not even the plastic joints..
... the copper stub outs to the water heater did crack open but the wirsbo aquapex was not damaged...I was amazed and very happy
I prefer to run the stuff like copper pipe using straight sticks
but some guys will install those manifolds....which seems like more work... The cost of the pex is dirt cheap I think a 300 foot roll of 1/2 aquapex is about 90 bucks.
http://s3.supplyhouse.com/images/pro.../2432-22-5.jpg
I have never, ever had a failure from a leaking joint using that hand held milwaukee expander....
Plumbducky and Alice Bond like this.
The Following 2 Users Say Thank You to Master Mark For This Useful Post:
Cal (05-18-2016), Qplumb (05-14-2016)
Old 05-14-2016, 11:51 AM   #8
View kiddplum's Photo Album My Photos
Default new to pex
i have been running pex for about 15 years now
started with the wirsbo aquapex and a manual expander
now I use the m12 cordless expander works great
but before that came out I switched to the zurn style cinch clamp system which I like for the 1 tool fits all the rings
I did not like the idea of a separate tool for each size ring as the copper crimp ring system uses
I have also used the newer style cinch clamps that have an ear on them which prevents them from sliding down the tubing before you crimp them
they all have their advantages dis advantages
you can make pex look good it requires a lot of straps though
when doing new construction I did a lot of hybrid systyems where I ran cpvc trunk lines in the basement used bullet manifolds and ran separate pex lines to each fixture
kiddplum is offline   Reply With Quote
Old 05-14-2016, 12:19 PM   #9
plumbdrum's Avatar
Use the Viega fostapex if you worried about looks. The aluminum keeps things nice and straight. Uponor is good for the fact that you have less restriction through the fittings but it's a pain in the a$$ in the winter with rings closing up. Your" time savings" gets thrown out the window chasing leaks in the cold. I switched to Viega because of that one reason when I was in business. Just my 2 cents.
The Following User Says Thank You to plumbdrum For This Useful Post:
wyplumber (05-14-2016)
Old 05-14-2016, 12:19 PM   #10
View paultheplumber1's Photo Album My Photos
I've been using watts and nibco for at least 15 years now. We use the ss cinch clamps and the poly fittings. Living in New England we experience extreme temp changes as well. For residential around here if your not using pex you can't compete
paultheplumber1 is offline   Reply With Quote
The Following User Says Thank You to paultheplumber1 For This Useful Post:
plumbdrum (05-14-2016)
Introduction Khazekstan New Member Introductions 3 02-05-2016 10:53 PM
The Introduction of Lucky Lucky Jack New Member Introductions 1 11-26-2015 12:23 PM
Plumbing Zone Introduction O'Grady New Member Introductions 11 09-25-2015 06:19 PM
Introduction Thudchkr New Member Introductions 2 09-13-2015 01:02 AM
Introduction; Chief Engineer Kerbouchard New Member Introductions 17 09-04-2015 01:42 AM
