SharkBite Certified
Ever need to cut into a pipe or repair a pipe with water in the system try freezing it on either side where you want to do the work. We do this on lots of high rises and fire protection systems.
Several methods are: 1. Dry Ice (CO2)- Make an insulated box around pipe where you would like to freeze and add dry ice ( note better result if flow of water is shut down) about 10 minutes pipe is frozen 2. Buy or rent pipe Freezing machine 3. Liquid Nitrogen - Had to do this on large systems filled with gylcol - made a insulated pipe or container larger than pipe feed liquid nitrogen into container around pipe. Make sure you have a outlet port on container as expansion of nitrogen is 1000 times that of the liquid. Caution with liquid nitrogen as it could freeze your skin if you come in contact with it. If the pipe is large in diameter you can rap 1/2" soft copper line about 10 to 20 turns around pipe , cover with insulation and run liquid nitrogen through 1/2" pipe to open air. This will freeze any liquid in the pipe including oil. |
| The Following 2 Users Say Thank You to OldSchool For This Useful Post: | gear junkie (03-07-2010), Protech (02-06-2010) |
Never done the freeze thing, I always use bread myself.
SharkBite Certified
Bread works only if the pipe is already open and you are trying to solder. But what if you have a boiler system or large building with domestic water and you either can not shut system down or there is no way to isolate the area with valves. Or if you did not want to drain system down because of loss of water treatment products in system (boiler). Very expensive to bring back water treatment to proper levels.
| The Following 3 Users Say Thank You to OldSchool For This Useful Post: |
#5 | |
I did use the dry ice one time when we could not find the curb cock for a house water service.
http://alsdrainservice.services.offi...m/default.aspx Only two devining forces have died for you. One is Jesus Christ and the other is the American soldier. One died for your soul the other died for your freedom. |
Where am I at?
We do that all the time to replace curbstops on water services. We use the General "Cold Shot" it uses liquid CO2 to create dry ice around the pipe. Works great but the water flow has to be stopped.
| How do u pipe water heaters flex or hard pipe? | arkyplumber | General Plumbing Discussion | 77 | 07-21-2011 06:06 PM |
| Sump pump discharge in freezing weather | Colgar | General Plumbing Discussion | 3 | 01-25-2010 10:14 AM |
| PEX and FREEZING TEMPS.... | Master Mark | General Plumbing Discussion | 20 | 01-09-2010 02:39 AM |
| Line Freezing 3" Chill Water lines | Rhitchcock | Plumbing Pictures | 2 | 08-25-2009 11:25 PM |
| Bathroom Sink/ Drain Pipe (Drain Pipe broke leading to ground) | bli182nk | General Plumbing Discussion | 4 | 01-12-2009 10:36 AM |
