I have a multi-family residential project - ground up. I took it over toward the end. The designer and Owner originally tried to go LEED, but it was too late in their process, so it was decided not to be a LEED job. But, since it is for a local University, they talked about going ahead and just installing the ultra low flow shower heads.
Schedule got in the way, so they just ended up putting on the regular heads to get a final, so they could move students in. Now I get on the job running the punchlist. After they moved in Students, etc. we switched all the heads to the low flow when they came in. Now, of course there are many warranty calls for the water pressure. The university personnel are claiming that we have a huge water pressure problem. I am telling them that we only really have a perception problem. We have 34 psi on a gauge at the entry to the building. Then 30 psi on the 2nd floor, 26 psi on the 3rd floor, and I am only getting 20 psi on the 4th floor. I cannot find anyone (our engineer, design engineer, architect, etc.) that will tell me what the minimum acceptable psi for a residential shower head would be. In other words, what our goal should be for the 4th floor. The Owner cannot even tell me what they think it should be, only that they should not be getting complaints. The line into the building is a 4" line and there is absolutely no room for a pump and the tank that would be required by the City. Any ideas? |
I aint CPV see in it?
I have the answer straight from the 03 IPC plmbing code book. But, before i give you the answer, how bout an intro, where are you, and what do you do?
My Name Is Rockstarplumber, and I Am Second.
Tallahassee Plumber Tallahassee Water line repair Tallahassee Tankless Water Heater Plumber Killearn Lakes Service Repair |
| The Following User Says Thank You to ROCKSTARPLUMBER For This Useful Post: | Redwood (04-02-2009) |
Hmm, guess he doesn't want the answer. He knows the name of the code book, but doesn't have the code book?
Cruise Director
Illinois Licensed Plumber
I guess it depends on the code you follow. Our code states a minimum of 20 PSI on the discharge side of the meter, and minimum of 8 PSI at the fixtures or the minimum required by the manufacture.
Minimum Water Pressure. The minimum constant water service pressure on the discharge side of the water meter shall be (at least) 20 p.s.i.; and the minimum constant water pressure at each fixture shall be at least 8 p.s.i. or the minimum recommended by the fixture manufacturer.
Ron Hasil Lic #058-160417 A-Archer Sewer & Plumbing specializing in: Tankless Water Heaters | Drain and Sewer Cleaning Sump and Ejector Pumps | Backflow RPZ Testing |
Cruise Director
Our minimum is 15 but there is no way I would ever plumb a 4-story multi-family at that. A new booster pump every 5-years or so could pay for a lot of over-sized copper.
Mark |
| The Following User Says Thank You to ToUtahNow For This Useful Post: | SewerRatz (08-01-2010) |
Chicago's working pressure from the mains is around 35 PSI I never been or seen what they use in the high rises, but I bet they got some huge ass booster pumps to get the water all the way to the top.
| Fiat shower pans, formica walls and Sayco shower valves | trnplmb | General Plumbing Discussion | 4 | 09-30-2009 04:18 PM |
| low pressure | jnsh2 | Residential Plumbing | 3 | 04-01-2009 01:13 AM |
| Negitive pressure HWT | PlumberDave | Commercial Plumbing | 6 | 02-02-2009 02:58 AM |
| Microsoft Office Word 2003 | Bill | Off Topic | 4 | 12-03-2008 03:25 AM |
| Balancing pressure | Bill | Residential Plumbing | 6 | 09-29-2008 06:29 PM |
