Always been an Achilles' heel of mine.
Deciding the best way to prime floor drains in a commercial project. I used to prime them from basins, but became very expensive buying trap seal primers and the time and material used to achieve the final product. I once even tried building a pyramid of tee's to prime each floor drain, but I figure it my pyramid was off level by a 64th of a degree, half the floor drains would get too much water, and the other half wouldn't get any water rendering the primers useless. I've started trying these primers ![]() The wholesaler carries these with 4 ports and I've separated them into 3 different groups at times. Does anyone have any better ideas for doing primers? Keeping in mind time and material as a factor (and obviously functionality) let me know what you guys use!
Shark-bite virgin |
Master Hack
Service Professional
#6 | |
Res./Comm. plumber 30+ years new const. P+P local 501,Steve |
Was told at last continuing ed class that trap guards were not approved for use here. (Ohio)
Did a pizza joint last year and installed that 4 way primer adapter. Works nicely for now. I hate primers - you know they'll either be wasting water or seized up in less than a year. Always leave plenty of pipe before and after the primer - no need to make it difficult for you to replace it in a year!
"Stay thirsty my friends" |
I don't know the Ontario code for trap guards in Ontario Canada. But we did a job that had 40 floor drains, we ended up priming them from the showers. But I don't like doing that, especially since the shower valves were inside a block wall that isn't accessible.
I just wanted to know what other options or ideas other people had, seems to be a gray area on a direct way on how to do them.
Shark-bite virgin |
we can put a hose bib off the cold line here under the lav. No trap primer needed. IPC.
I like the trap guards, just not sure they are approved in my area. |
#10 | |
SharkBite Certified
| Options for baseboard replacement | Indie | Boilers, Hot Water & Steam Heating | 17 | 12-07-2011 09:13 PM |
| Tankless options | Indie | General Plumbing Discussion | 52 | 03-16-2011 08:40 AM |
| Options for this tub/shower | Indie | General Plumbing Discussion | 25 | 09-23-2010 07:18 PM |
| Van storage options | gear junkie | Plumbing Tools and Equipment | 12 | 12-16-2009 02:31 AM |
| Hello from Central IL | Links_56 | Introductions | 8 | 03-06-2009 07:57 PM |
