Cast Iron should be banned from plumbing. Does anyone else agree with this statement? In my experience using cast or even replacing it, it is always corroded and full of everything you can think of sticking inside the pipe. Now I see no problem using it in venting in an open return system, you have to for fire codes. Venting will not hold materials like a drain will. I really think PVC or ABS should be the only thing allowed in waste lines. I even have my doubts about ABS. But that is better then cast.
I worked for a company that used ABS too, it was fine. But I like PVC better. But my point was No hub sucks
I have never had more callbacks then on jobs with cast iron no hub. The pipe seems to just clog easy. It is horrible stuff. Never do you see PVC holding fats and oils like no hub. Last edited by Ron; 09-30-2009 at 11:46 PM.. Reason: Post Merge |
| The Following 2 Users Say Thank You to Reinhard For This Useful Post: | Protech (10-01-2009), ROCKSTARPLUMBER (10-01-2009) |
Banned sounds so permanent....I would miss it when it's gone, used it for most of my life..
"I believe human-beings and fist can co-exist peacefully....." GW |
| The Following User Says Thank You to SlickRick For This Useful Post: | Plumbworker (10-01-2009) |
Yes I see pvc packed with solid grease. Thats the users fault. I wouldn't consider a clogg a callback unless the pipes installed wrong. maybe I'm reading your post wrong......what are the cause of the callbacks?
| The Following 5 Users Say Thank You to TheMaster For This Useful Post: | Associated Plum (11-16-2009), breid1903 (11-01-2009), SlickRick (09-30-2009), trick1 (10-29-2009), UnclogNH (11-16-2009) |
Another thing that sucks, paying for insulation and fire caulk.
Wow have fire codes gone crazy, you must fire caulk and we even had to get out vacuum line fire insulated at $8.00 a foot. Crazy. the cause was using cast iron no hub, it always seems to clog easy Last edited by Ron; 09-30-2009 at 11:46 PM.. Reason: Post Merge |
Trust me. I'm a doctor.
I don't have a problem with iron. You never seen HO's standing around talking about how plumbers are too expensive 'cause any monkey can put together iron.
Can't say that for plastic.
My proposal for a 28th Amendment to the United States Constitution. "Congress shall make no law that applies to the citizens of the United States that does not apply equally to the Senators or Representatives, and Congress shall make no law that applies to the Senators or Representatives that does not apply equally to the citizens of the United States." |
| The Following 9 Users Say Thank You to Pipedoc For This Useful Post: | 422 plumber (10-29-2009), Associated Plum (11-16-2009), muck (10-02-2009), RealLivePlumber (10-01-2009), Regulator (11-01-2009), SewerRatz (10-01-2009), SlickRick (09-30-2009), user2091 (11-03-2009), WestCoastPlumber (10-04-2009) |
#10 | |
Calm down son, Your not taking Rocket Fire..... ![]()
| Cast iron to PVC | TryTibbs | Residential Plumbing | 3 | 08-07-2009 04:25 PM |
| cast iron pt.2 | skw83 | Plumbing Pictures | 7 | 04-20-2009 04:51 PM |
| Cast Iron | skw83 | Plumbing Pictures | 12 | 04-16-2009 10:02 PM |
| First cast iron job | Bill | Residential Plumbing | 48 | 12-21-2008 02:17 PM |
| Tie into cast iron | Bill | General Plumbing Discussion | 20 | 09-11-2008 01:07 AM |
