The current trend with modern commercial condensing boilers is for smaller water volume and circulating water past heat exchanger. Obviously this creates possible problems due to the larger numbers of parts (pumps )etc.
Anyway I have recently been shown (in advance of launch) a new "old fashioned" style boiler with what seems to be impressive technical specs (please see below) I just wanted to know whether anyone felt that the modern boiler design was better for any other reasons other than size? Efficiency of the model below seems just as good but I am sure there must be a catch. 108% gross efficiency (98% net) NO minimum flow rate, meaning no secondary circulation pumps and less electrical consumption NO minimum return temperature Mixed temperature returns need no additional equipment as just plumbed straight into water tank. 12 year guarantee longest in the industry Cascades are done in parallel not serial, meaning no computers or other equipment is required. Dirt in system settles in bottom of tank meaning boilers can be connected to old heating systems without any modifications. NOx emissions less than 16 ppm Noise less than 35db at maximum output Single phase electricity on all models saving further electricity Built in building communications and remote operation on electronic control panel. Modulating burner - 5:1 turn down ratio Pre-mix burner |
Hi, welcome to PZ. I am not sure, but Nathan does have an HVAC site somewhere. I am trying to find a link for you. I am not going to close this thread as plumbing and water heating go together. I will find the link and post it for you.
Here is one for contractortalk HVAC area
http://www.contractortalk.com/f6/ And, here is his HVAC site http://www.hvacsite.com/ Both are Nathans sites and you may get better responses there. If I remember there may be a few here who dabble in boilers.
#4 | |
Master Plumber
| The Following User Says Thank You to 22rifle For This Useful Post: | gusty60 (05-04-2009) |
Illinois Licensed Plumber
I am suprised no one has hassled you about an Intro, please give us an Intro and tell us a bit about yourself.
Ron Hasil Lic #058-160417 A-Archer Sewer & Plumbing specializing in: Tankless Water Heaters | Drain and Sewer Cleaning Sump and Ejector Pumps | Backflow RPZ Testing |
Plumba
I wanna live in Qatar. In a balloon. With a harem. Without boilers.
You're right in that newer isn't always better. I install regular standard systems and they last years and years giving adequate service. |
| The Following User Says Thank You to Plumber For This Useful Post: | gusty60 (05-05-2009) |
#8 | |
| Does a person's integrity determine whether you take advice from them? | 22rifle | General Plumbing Discussion | 19 | 02-20-2009 12:06 AM |
| Giving bad advice/sabatoging H.O.'s | Sheppard | General Plumbing Discussion | 37 | 02-16-2009 10:57 PM |
| need advice on Delta kitchen faucet... | opalomarez | Residential Plumbing | 4 | 02-15-2009 06:23 PM |
| Steffes Boiler | Mike Jessome | General Plumbing Discussion | 0 | 01-29-2009 05:26 PM |
| Starting a new business soon. (Advice?) | CentralPlumbing | Business, Marketing, and Sales | 3 | 01-29-2009 09:22 AM |
