180 degree tankless for commercial dishwasher - Plumbing Zone - Professional Plumbers Forum
Old 02-22-2013, 03:29 PM   #1
Protech's Avatar
Default 180 degree tankless for commercial dishwasher
What should I use?
The problem: They currently have a lochinvar copper fin 740,000btu boiler cranking out 180 degree water and circulate it through the entire restaurant. This is bad for obvious reasons. They need 180 degree water for the dish washer only. That dish washer only pulls 3gpm or less and has it's own dedicated 3/4" hot water loop running from the boiler room to the dish washer roughly 150' away.
So I was thinking a tankless unit that could boost the temp from 140(minimum setting of boiler) to 180 would be ideal. The boiler could be turned down to 140 and that would save a ton on fuel and would be easier on the boiler. Currently they have had to replace the boiler every 5 years on the dot.
I guess the ideal thing would be to put the tankless right next to the dish washer as they have space on the wall. That would remove the need for recirc and the associated energy loss. My only concern there is the tankless getting splashed and sucking in grease/smoke/what ever as it's in a commercial kitchen.
What unit would you recommend?
Thanks.
Old 02-22-2013, 03:38 PM   #2
View Catlin987987's Photo Album My Photos
The Navian NP-240 can do 180F
Everyday Normal Plumber
Catlin987987 is offline   Reply With Quote
Old 02-22-2013, 03:44 PM   #3
Protech's Avatar
Seems pretty pricey for a 40 degree boost at 3gpm or less.
Old 02-22-2013, 04:08 PM   #4
They do make elctric booster heater just for that purpose, under the dishwasher..
The Following 3 Users Say Thank You to rjbphd For This Useful Post:
bizzybeeplumbin (03-23-2013), Gettinit (02-22-2013), johnlewismcleod (02-25-2013)
Old 02-22-2013, 04:15 PM   #5
Protech's Avatar
Yeah but at $0.12/kwa, they would be spending hundreds of $ a month just on that booster heater. The tankless would pay for it self in a year.
No one makes a 180 degree heater for like $800-$1000?
Old 02-22-2013, 04:26 PM   #6
Ya got a poi t there.. I remmy a drawing where u can piped in serie after the 140 temps heater into a smaller heater set at 180 temps and piped to the DW with return pipe back to small heater.
Old 02-22-2013, 04:45 PM   #7
Relic's Avatar
View Relic's Photo Album My Photos
Do they want to change their set up for two water heaters? You could just offer them a tempering valve installation to temper all but the dishwasher.
Relic is offline   Reply With Quote
The Following User Says Thank You to Relic For This Useful Post:
JERRYMAC (02-24-2013)
Old 02-22-2013, 04:46 PM   #8
Protech's Avatar
That's on the table, but that still requires heating the boiler to 180 which is abd for it and not as efficient.
Old 02-22-2013, 09:46 PM   #9
View pipes's Photo Album My Photos
So if electricy is $0.12/kwa, is gas free? Can we see your calculations for the hundreds a month?
Do you understand how the booster and dishwasher work together and just how much water @180 is needed and for what duration.
A simple booster by Hatco or the like , is the simplest and least expensive way out.
If you are saving them $$$$ on reducing wear and tear as well as fuel on the boiler side they won't notice the spike in electric costs.
I am normally the quiet guy in the back but , I really hate when people try to reinvent the wheel by adding corners to it.
pipes is offline   Reply With Quote
The Following 7 Users Say Thank You to pipes For This Useful Post:
bizzybeeplumbin (03-23-2013), CaberTosser (03-10-2013), dclarke (02-25-2013), JERRYMAC (02-24-2013), johnlewismcleod (02-25-2013), OldSchool (02-23-2013), rjbphd (02-22-2013)
Old 02-22-2013, 09:49 PM   #10
With enough corners you can make a wheel
45 Degree offset formula swedishcharm21 General Plumbing Discussion 142 06-03-2015 04:38 AM
How much 150 degree water would it take saysflushable General Plumbing Discussion 10 02-10-2013 03:13 PM
Associate Degree complete user2090 Off Topic (Non Trade) 12 12-08-2011 05:27 PM
panoramo 360 degree CCTV system ianclapham Drain and Sewer Cleaning 4 09-04-2011 07:49 AM
Commercial Tankless Heater TheSkinnyGuy Commercial Plumbing 6 08-05-2010 09:23 PM
