Any suggestions? I don't want to use the cpvc plastic bodied valves because they frequently leak out of the packing and cannot be serviced. I saw some brass/bronze/copper ball valves a few times that have cpvc inserts built into the metal valve body. Those would be nice because I would have a brass/bronze/copper valve with an actual packing nut but I wouldn't need the expensive brass MIP adapters. I can get a 1.5" full port brass ball valve for less than $20 but now one around here sells a 1.5" cpvc by brass MIP adapter for less than $35.
The darn adapters cost more than the valve they are connected too. ![]() I can't/won't use plastic cpvc MIP adapters as this is a hot water application. Does anyone know where to get those 1.5" metal valves with the cpvc inserts built right in? Any idea what they cost Many thanks. |
#3 | |
| The Following User Says Thank You to TheMaster For This Useful Post: | Protech (08-19-2010) |
Those valves cost a bit much and I don't think Mr. Patel is going to go for it at those prices. I'll give him 2 options, the Hayward true unions and the Sioux Chiefs.
The Haywards may be plastic but they have a beefy handle (well, as beefy as plastic gets anyway) and double o-rings on the stem. Even if the stem ends up leaking like the current POS valves are doing, at least changing the valves will be a snap with the unions. The Haywards can also be crammed into the short pipe lengths in the boiler manifold in question so that's a plus. If I go with the Sioux Chiefs I'll have to put double 90's on each side of each valve. That's a whole’lotta 90s. I'm leaning more towards those Haywards the more I think about. Check'em out: http://www.haywardflowcontrol.com/pd...all_Valves.pdf |
I use those valves on DI water quite a bit in 1" to 4". They have performed well. You won't be disappointed.
Easily serviced. The 2" to 4" ones are little on the sticky side. Be very careful when you turn them on. They don't tolerate vibration is my only gripe..... |
| The Following User Says Thank You to ILPlumber For This Useful Post: | Protech (08-19-2010) |
Is that MR. Patel in Nick Patel?
Paul
General Manager Progressive Services LLC Clermont, Florida http://www.progressiveservices.com |
I wouldn't disclose that kind of information to a potential competitor. Nothing personal, it's just business.
| Delta "25919" "Lewiston" 2-handle faucet review | Protech | Plumbing Material and Products | 14 | 03-12-2010 07:04 PM |
| In a 1.25" cpvc jam in a high-rise | Protech | Commercial Plumbing | 9 | 02-25-2010 05:51 PM |
| Are People Generally "Good" or "Bad" | DUNBAR PLUMBING | Off Topic | 5 | 04-01-2009 09:17 AM |
| Gate Valves Or Ball Valves-vote! | WestCoastPlumber | General Plumbing Discussion | 36 | 03-31-2009 01:13 AM |
