Toilet riser platform? - Plumbing Zone - Professional Plumbers Forum
Like Tree10Likes
Old 04-18-2017, 07:20 PM   #1
Default Toilet riser platform?
So that flange I had to go look at is indeed a half inch or better to high. Schedule 30. The HO really doesn't want us to hack into his kitchen ceiling and would like us to install a riser platform like the Toilevator. Has anyone installed one of these before? PITA or an Ok product for this situation? I've never even seen one. I've seen HOs made ones... and they aren't very impressive.
Old 04-18-2017, 09:07 PM   #2
1/2" too high may be ok. Measure the exact height of the flange, flip the toilet bowl over and measure the depth of base to the china. There's probably 3/4"-1" of height.
cmh and MACPLUMB777 like this.
The Following User Says Thank You to Debo22 For This Useful Post:
OpenSights (04-18-2017)
Old 04-18-2017, 10:33 PM   #3
HO said he tried to set it and it wobbled. I could try to push further down with new screws, but I might get backfall.
Without getting out the tape, but using backyard pinpoints it's right above kitchen cabinets with a chase above them. Drop doesn't drop deep enough to go into the chase.
Old 04-18-2017, 10:53 PM   #4
I wouldn't take a homeowners word for it. It could have been wobbling on the uneven floor.
sparky and WashingtonPlung like this.
Old 04-19-2017, 12:26 AM   #5
chonkie's Avatar
Schedule 30 pvc? Really?
First see how much pipe is between the flange and the 90, is there enough to cut the flange off with an inside cutter and glue a coupling, new piece of pvc and new flange set at the right height.
If there isn't enough space to do that, my next option would be to cut the flange and peel it's hub off the pvc or from inside the pvc depending on how they roughed it in.
mtfallsmikey and sparky like this.
The Following 3 Users Say Thank You to chonkie For This Useful Post:
GAN (04-19-2017), sparky (04-22-2017), Tommy plumber (04-19-2017)
Old 04-19-2017, 07:11 AM   #6
He ripped out the old tile and cement board and replaced with cheaper thinner board and tile.
Old 04-19-2017, 07:18 AM   #7
Problem is whoever plumbed it used a regular 90 and male flange... the old brittle yellow pvc.
It's a bad situation for the HO any which way. If he was smart he would've called us before he put the new floor down... but we all know how that goes.
Honestly I think his best bet is drywall repair.
mtfallsmikey likes this.
Old 04-19-2017, 02:18 PM   #8
Plumbus's Avatar
If it's not too high, shim up the ring and use those longer screws you mentioned.
The Following User Says Thank You to Plumbus For This Useful Post:
OpenSights (04-19-2017)
Old 04-19-2017, 03:53 PM   #9
A bit off topic but a good fitting to have is a closet street 90 3" hub -- 4" spicet you use a 4" flat flange and you can cutoff what you don't need from the spicet.
http://www.nibco.com/Fittings/Plasti.../?pageNumber=2
scroll down the fitting I'm talking about is right below ser 90
Old 04-19-2017, 05:07 PM   #10
That could save our butts sometimes! I'll have to if it's legal out here. It'd be a btch to cable if you had to.
New Toilet (Leveling vs. Wax Seal) dschae1 General Plumbing Discussion 7 12-28-2016 09:36 PM
Toilet drain cleanout nicksab Residential Plumbing 5 11-19-2016 10:22 PM
Common Toilet Plumbing Problems kwikproplumb Plumbing Material and Products 13 06-28-2016 10:18 PM
Old school toilet and porcelain toilet bolt caps. chonkie Plumbing Pictures 7 11-19-2015 08:26 PM
Toilet flushing issue gunlocators General Plumbing Discussion 4 09-18-2015 08:11 AM
