Old 03-03-2010, 11:39 PM   #1
View Nevada Plumber's Photo Album My Photos
Default Pump question
I need to replace an electric water heater in a basement that has no floor drains in it. Right now the relief valve drain is PVC, and goes up about six feet before it goes who knows where. Obviously, I can't leave it like that.
What I would like to do is install some type of pump, and then run the relief line to that. This pump would only serve the water heater.
I know very little about the different types of sump pumps. We have very, very few houses with basements here, and only a small percentage of those have fixtures in them.
Can someone point me in the right direction for a unit to accomplish what I need to do?
Nevada Plumber is offline   Reply With Quote
Old 03-04-2010, 12:21 AM   #2
View PlumberDave's Photo Album My Photos
An accepted practice here is to just drop the relief to the floor and install a 125psi relief to outside where your able.
PlumberDave is offline   Reply With Quote
Old 03-04-2010, 06:43 AM   #3
The Pipe Whisperer
ranman's Avatar
View ranman's Photo Album My Photos
here is a link for pumps.
http://www.do-it-yourself-pumps.com/...agesystems.htm
an idea open the floor and add a emergency floor drain, run it to a small sump and pump it out to grade.
does the drains for the house go out high or can they be located under the floor?
ranman is offline   Reply With Quote
Old 03-04-2010, 08:05 AM   #4
AAAAAAAAHHHHH!!!
Indie's Avatar
View Indie's Photo Album My Photos
Why pump it?
Indie is online now   Reply With Quote
Old 03-04-2010, 08:42 AM   #5
SummPlumb's Avatar
View SummPlumb's Photo Album My Photos
What is wrong with it going up? The line is under pressure when it pops off. Put a drip leg on the bottom of it. Adding a pump only intensifies the situation. How do you know if the pump is working? Maybe our inspectors here are different?
"The Plumbing Guru"
SummPlumb is offline   Reply With Quote
Old 03-04-2010, 09:50 AM   #6
SharkBite Certified
OldSchool's Avatar
View OldSchool's Photo Album My Photos
I dont think that would be a wise choice to pipe the relief upwards. This could get blocked by corrosion as the pipe will remain full of water once the relief valve has closed. In the future this could be like not having a relief valve at all if it is stuck closed .
In Ontario, if the appliance/equipment with the relief is on the lowest floor level (basement)the relief only has to be piped 6" above the floor. All other installations on floors above need a pan that is piped to a drain line.
Originally Posted by U666A View Post
My bad mood will fade, your ignorance will last a lifetime...
OldSchool is online now   Reply With Quote
The Following 2 Users Say Thank You to OldSchool For This Useful Post:
rocksteady (03-05-2010), SlickRick (03-04-2010)
Old 03-04-2010, 11:45 AM   #7
futz's Avatar
View futz's Photo Album My Photos
Where I live, if it's absolutely impossible to get the temp & pressure relief line to a drain or outside without going overhead (old houses) then the inspectors will accept piping down from the valve maybe 6" or 8" and then up and overhead or whatever (they obviously won't accept this on new construction - just repairs or renovations). Then we have to drill a 1/8" or so hole at the low point so the line can drain if it gets full. Keeps the valve from corroding to death. If the valve pops that small leak is far preferable to having a house full of water.
futz is offline   Reply With Quote
Old 03-04-2010, 11:58 AM   #8
How about installing the water heater in a pan without a drain...direct the relief valve pipe into the pan with a "wags" valve. Stop the water heater from flooding the basement and the relief valve.
The Following 2 Users Say Thank You to TheMaster For This Useful Post:
Airgap (03-04-2010), SlickRick (03-04-2010)
Old 03-04-2010, 06:40 PM   #9
View gladerunner's Photo Album My Photos
Problem with pumps is they have thermal overloads in the motors, so the hot water can actually cause the pump to shutt down. (it thinks the motor is overheating). you would need to use something made for heat like a steam condensate pump
gladerunner is offline   Reply With Quote
Old 03-05-2010, 10:19 AM   #10
SharkBite Certified
OldSchool's Avatar
They should invent a relief valve that also shuts off the cold water supply to the tank and maybe also have it interlocked with the fuel source to shut it off. Oh and by the way if you take my idea and patent it I though of it first LMAO
Zoeller M57 Pump Question smaerd58 General Plumbing Discussion 8 03-09-2010 03:48 PM
well pump misery arty28 Introductions 2 03-28-2009 10:37 AM
another well pump express Residential Plumbing 15 02-25-2009 12:00 PM
help with well pump express Residential Plumbing 4 02-22-2009 11:09 PM
Recirculating pump Surfrat General Plumbing Discussion 2 02-18-2009 09:32 AM
