To pull or not to pull - Plumbing Zone - Professional Plumbers Forum
Old 01-04-2012, 11:46 PM   #1
PH Plumbing
love2surf927's Avatar
View love2surf927's Photo Album My Photos
Default To pull or not to pull
Do you guys pull the nut and ferrule on compression angle stops if the threads match, or just swap the stop and call it good. Everyone I've worked for in the past always said if the threads match (i.e. old brasscraft to new brasscraft) just swap the stop but now that I have my own business I change everything, but once in awhile you run into one that has been over-tightened so much it crimps the sh** out of the copper and the new ferrule wont seal. Just curious what the rest of the plumbing world is doing.
love2surf927 is offline   Reply With Quote
Old 01-05-2012, 12:00 AM   #2
View Epox's Photo Album My Photos
If it looks willing enough and access is easy enough I replace, if not and the nut and ferrel appear to be fine I leave it on. Done this for years and yet to regrett it. I know some are bent on changing them out and I certainly have no problem with it. I say if you believe in changing them out 100% by all means do it. For the most part it's fine either way unless the thing is ancient.
I don't do PERKY.
Epox is offline   Reply With Quote
Old 01-05-2012, 12:05 AM   #3
AlbacoreShuffle's Avatar
View AlbacoreShuffle's Photo Album My Photos
I try to pull them "IF" there is enough room to cut off a stuborn one without having to open the wall.
If it looks like trouble , I'll use the old nut and ferrule .
AlbacoreShuffle is offline   Reply With Quote
The Following 3 Users Say Thank You to AlbacoreShuffle For This Useful Post:
Epox (01-05-2012), greenscoutII (01-05-2012), RealCraftsMan (01-05-2012)
Old 01-05-2012, 12:08 AM   #4
rocksteady's Avatar
I like to do it on all of them but I'd say probably 2-3% of the time I leave it on because it looks like a can of worms opening up.
Paul
Rocksteady Plumbing
(805) 237-7625 (ROCK)
The Following 2 Users Say Thank You to rocksteady For This Useful Post:
Epox (01-05-2012), Hillside (01-05-2012)
Old 01-05-2012, 12:10 AM   #5
okcplum's Avatar
View okcplum's Photo Album My Photos
i always change them out. i use a olive splitter, sorry, ferrule spitter.
i know them as olives as thats what we have called them since i have been in the game 24 years now.
the reason i do is because when i tried to just change the stops or whatever else i tried to get away with when i first started in the plumbing game my boss would always make me re do it at my own cost, i may add, so i learned fast and it has just stuck with me.
okcplum is offline   Reply With Quote
The Following User Says Thank You to okcplum For This Useful Post:
Epox (01-05-2012)
Old 01-05-2012, 12:33 AM   #6
I remove the old nut and ferrule. If it's stubborn, I use this: http://www.faucetdepot.com/prod/Pasc...ller-21586.asp
No matter how tight the ferrule is sqooshed onto the copper stub-out, the pasco tool pulls it right off.
Qball415 (01-05-2012)
Old 01-05-2012, 12:47 AM   #7
View JK949's Photo Album My Photos
99% I use the Saf T Kut ferrule splitter. Only done a handful where I left the original on. I check that the stop fully fits on the stub before tightening. If the stop only goes on partway, that's inviting a leak.
JK949 is offline   Reply With Quote
Old 01-05-2012, 01:02 AM   #8
Hillside's Avatar
View Hillside's Photo Album My Photos
I use the pasco tool also, it's scary when u can grab the nut with channys and slide both nut and ferrule off the copper without a problem, I use wd40 or 3 in one when removing ferrules with the pasco tool, it helps a lot. 99% of the time I change it all......... Oh and I ream the pipe that the other plumber forgot to do 90% of the time, if possible i cut off appx 3/8's" of the copper to make sure the new ferrule seats well
Hillside is offline   Reply With Quote
The Following 2 Users Say Thank You to Hillside For This Useful Post:
ChrisConnor (01-05-2012), love2surf927 (01-05-2012)
Old 01-05-2012, 01:06 AM   #9
RealCraftsMan's Avatar
View RealCraftsMan's Photo Album My Photos
No sir that's really the price and no I will not take any off.
RealCraftsMan is offline   Reply With Quote
The Following 6 Users Say Thank You to RealCraftsMan For This Useful Post:
ChrisConnor (01-05-2012), gusty60 (01-06-2012), Hillside (01-05-2012), HOMER (01-05-2012), love2surf927 (01-05-2012), Qball415 (01-05-2012)
Old 01-05-2012, 01:06 AM   #10
I know, what's up with that? You wonder how the stop didn't blow off the wall...... Sometimes even, you can slide the nut and ferrule off by hand.....that's when I'm like...
The Following 2 Users Say Thank You to Tommy plumber For This Useful Post:
ChrisConnor (01-05-2012), Hillside (01-05-2012)
Weatherguard aluminum pull out drawers rocksteady Plumbers Swap 0 12-15-2010 12:35 AM
Pull out your crystal ball user2090 Off Topic (Non Trade) 6 10-04-2010 07:28 AM
Anyone pull an April Fools prank on a coworker? Lee in Texas Off Topic (Non Trade) 2 04-03-2010 10:41 AM
Pull Behind Sewer Jetter Plumberman Drain and Sewer Cleaning 15 04-02-2009 12:19 AM
Pull out bed box Bill General Plumbing Discussion 10 08-22-2008 11:08 PM
