Was at one of my regular customers for a quick service call. They had an old watts prv that was leaking right after the water meter on a 3/4" main.
The customer had already bought a new pressure reducing valve. And like all customer bought stock it is a cheap piece of garbage. I installed it and it had a weep hole in the brass casting! So he returned it and got the same model same company. I installed it and it worked fine i tested the pressure on the house and set it for 60psi. Then 3 days later he calls me up complaining of noise in his water pipe. I get over there and test the faucet in the kitchen. When you turn it on with a small trickle the cold water main vibrates very bad and makes a whine sound that is very loud. Ive never heard anything like that. so i was playing with a ball valve after the prv. With a faucet wide open i can start to close the ball valve when it gets to 9/10ths closed the vibration and whine starts. then when i open it up all the way it goes away. Im going to pick up a WATTS valve which i always use and see if it helps. Has anyone ever incountered this problem?? Im a little perplexed because he never had this noise with the other prv in over 20 years!! Its driving me crazy!! |
#2 | |
Registered User
Registered User
Tell us a little about yourself, type of plumbing, yrs, etc. You will be welcomed and receive more responses, kinda like the skull and bones.
Go to the link below. http://www.plumbingzone.com/f3/ |
Registered User
The chatter is being caused by a loose or soft piece of rubber. If the chatter was not there before the new PRV was installed, it is most likely the diaphram, and will need a new one, or replace the defective PRV. If you think it may be related to just one faucet, then you have a loose washer in the faucet or stop.
| The Following User Says Thank You to SlickRick For This Useful Post: | drsplumbing (11-01-2010) |
| Noise in water heater | aadams | Introductions | 10 | 10-12-2010 07:53 PM |
| What kinds of things have you made with pipe/fittings? | Scott K | Off Topic | 34 | 06-04-2010 10:07 PM |
| Replaced Cast Iron (CI) with ABS - NOISE! | NPBSurfr | Residential Plumbing | 2 | 09-05-2009 01:17 PM |
| There are only two kinds of plumbers... | 22rifle | General Plumbing Discussion | 12 | 08-08-2009 01:07 PM |
| Vibrating noise from toilet | IrishPlumber | Residential Plumbing | 29 | 07-23-2009 10:08 PM |
